Goetz Geschrieben 13. August 2019 Geschrieben 13. August 2019 (bearbeitet) vor 2 Stunden schrieb ademes: how to define a table in Lua that is available to all events? Use the main script. In the event manager, click the + sign and instead of adding an event or a modul, add a script. You can have one main script per layout and that may hold your table and other constants. And no, a table cannot be an object variable. Not yet, anyway. But Neo is considering this option. Bearbeitet 13. August 2019 von Goetz
Neo Geschrieben 13. August 2019 Geschrieben 13. August 2019 Hi, vor 3 Stunden schrieb Goetz: You can have one main script per layout and that may hold your table and other constants. to avoid misunderstandings, you can have a "main script" per module. All scripts of all modules are finally merged together, so that a (sub)module can declare own global functions and constants. Kind regards, Neo
ademes Geschrieben 13. August 2019 Geschrieben 13. August 2019 Hi Goetz and Neo, Thank you for explanation. I'll try this soon. André
