Hello Goetz
Really great what you have make. I did look your video's (y)
Thank you for making this video,
I am sure that a lot of people are going to use you sample.
Great explanation how you can work with variable,
I have one more question. :$
Can you please finisch your sample that signal B103  give free the trains on signal P200 / P204 when signal B103 is free .
Than the cirkel is round and we can make a lot of new things becausee of your really great sample.
Klasse Goetz (y)(y)(y)
Best regards from Holland,
Ger
Hello Ger Klunder,
vor 2 Stunden schrieb ger klunder:
I'll do my best to continue the explanation and include the explanation you asked for.
Currently, my second monitor is out of order and I need two for any Twitch broadcast.
Thank you very much for your kind words regarding my video.
Goetz
Hello Goetz,
Oke than we can only wait, hope your problem is solve very soon
I have try to make something by myself.
And I am very happy with this.
But I am very sure that I did make the script maybe to big :D
Schattenbahnhof 03 (WIP).mbp
Bearbeitet von ger klunder
vor einer Stunde schrieb ger klunder:
And it works very well.
The on/off switch is a nice addition (y)
vor 24 Minuten schrieb Goetz:
Thanks (y)
Hello Goetz,
I have try (many many times) to make with your sample a second station.
When I did it the same like you did everything did go wrong.
I did have change all that the have the own event, keyword, variable. but then again everything went wrong.
I did make a new sample that the second station is clean without any script or keyword or variable.
I hope you will help me again:$ with this sample Schattenbahnhof 04 (WIP)
THANK YOU
Ger
Schattenbahnhof 04 (WIP).mbp
vor 5 Stunden schrieb ger klunder:
I would, Ger
But your duplicate circle is completely bare. The contacts have no variables and no keywords.
Nor do the signals. Nor do I find anything in the EV related to your half of the layout.
Is this - maybe - the wrong layout?
greets
Goetz
Hello Goetz,
Thank you for your reply.
This is what a wrote this morning.
So this was not the wrong layout:P
This is did special for you that I was sure that I become a good sample.:$
Below the one were I was busy with, but not good work, I think version 25 :P:D
There come a moment that I don't understand it anymore.:D
Again thank you Goetz.
Best regards,
Ger
Schattenbahnhof 05 (WIP).mbp
vor 20 Minuten schrieb ger klunder:
I'm sorry, Ger - I somehow missed that part.
But a clean example doesn't help me to help you. With the clean example I can only repeat what I did before and you wouldn't learn anything new from that. You're failed attempts are more useful because I may (with luck) recognise where your knowledge gaps are.
Equally, a sentence like "I don't understand it anymore" is of very little use to me. You must be a lot more specific about what it is that you don't understand. I can't look into your head. So it's your duty to describe to me in detail what's going on inside. (And please refrain from humorous descriptions at this point if you want help and not just entertainment!)
And now I'll see if I can figure out what your difficulties are by studying your example No 5
After a quick check of your example 5:
Everything seems to work fine except for the switch at the entrance side not being set at all.
Bearbeitet von Goetz
