3044 -
Beiträge erstellt von EASY
Hi trevor,
... good idea
... i tested your plugin with the MBS project "Gablerspitzbergbahn" and i got some questions:
What is the condition for a "Bad Name" (name with blank seems to be one condition...) and...????
When i start the plugin, then i get this:
... as you can see there are 1600 "Duplicates"...
... so i fixed then...
...then i get 888 "Bad Names"...
i fixed them...
... there is still one "Bad Name" and i can't fix this name...
... but now i got 1 "Unknown References" (... is the reference the name which can not be fixed?) or what does "Unknown References" mean?When i try the plugin with the MBS project "Gotthard Nordrampe" then 9493 "Duplicate Names" will be found. If i fix them it will take a long time (several minutes) to fix the names. I do not know if you do... but in this case (rename objects) using a "commandgroup" in the programm should be much faster...
Hi
The first plugin is now avaiable in German and English ("Tunnel-Setzen/ Tunnel Setting/ de/en") (see here)
The next one (to be translated) will be "Gleis-Setz-Tools" / ("Track-Setting-Tools")
I hope Curt84328 will help me (again)
Das Plugin ist nun auch auf englisch. Die deutsche oder englische Version wird in Abhängigkeit von der Spracheinstellung im MBS aufgerufen.
The plugin is now also in English. (Depending on settings "language" in 3D TS in German or English).EASY
Hi trevor,
the simulation in 3D TS runs in Edit view () and in Simulation view () and you can pause() / run () simulation in both views.
Hi trevor,
Zitatvor 5 Stunden schrieb trevor:We really need pause / run simulation commands....
... this is not clearly written in the wiki (-> "activate / deaktivate Animation in studio"). This (also) pause / run simulation.
... da ich die "Plauderecke" nicht mehr finde, stelle ich es hier einmal ein... da ich Euch diese Technik nicht vorenthalten wollte....
Ich finde die "Konstruktion" einfach genial... und dabei sooo einfach...
(... gefunden auf einer Gewerbeausstellung [... als Beispiel für das Schneiden mit einem Wasserstrahl])...
P.S. ...Prinzipiell sind wir hier im Südwesten technisch (auch) schon etwas weiter...
EASY -
Hi trevor,
... what do you want to do?
Can you give an example (3D Train Studio project and programm)?EASY
Hi trevor,
... as far as i know the interface is also "synchronisized" with the frame rate (like the event manager).
An exception is the "group command" which runs in a "asynchron state"... see wiki "Gruppenkommando" (in German)... but there are somme "special features" with the answer of a command...EASY
Hi Curt,
... well done !
.... most time i do not need the sound to understand what to do...
... in German we say "Bilder sagen mehr als tausend Worte" (Pictures say more than a thousand words)... this is true for your videosEASY
... was mir an der ganzen Diskussion etwas fehlt ist eine kurzfristige Lösung.
Die Modelle der Modellbauwelt sind nun einmal da und Franz möchte dies nicht weiterführen.
Nun was ich bisher dort gesehen habe sind schöne Modelle um die es sehr schade wäre, wenn sie einfach so "verschwinden" würden.
Leider habe ich mich mit der Materie noch nie beschäftigt, so daß ich sagen kann, gib das ganze einfach mal rüber...
Unabhänging davon, wie die Zukunft nun auch aussehen mag (... mit Zustimmung der Modellbauer könnten ja die Modelle nach und nach in den "neuen" Katalog mit einfließen...) wäre es hier bestimmt für einige Leute "beruhigend", wenn sich jemand als "Bewahrer der Modelle der Modellbauwelt" melden würde...
EASY -
Hallo Porey61,
1) Bild laden (bei Heftklammer unterhalb Deines Beitrages)...
2) ... Schreibmarke in Deinem Beitrag auf die Zeile (neue Zeile) setzen, wo das Bild hin soll...
... und in der Bildvorschau ( "Hochgeladene Bilder" unterhalb Deines Beitrages) auf das "+" Zeichen klicken (-> In Beitrag einfügen).... Schreibmarke unterhalb des Bildes setzen und weiterschreiben...
EASY -
Hi trevor,
This is not possible at enent control.
I once made a Plugin "MBS-Drehen-EV" where you can rotate a objekt at evert control with a object variable.
You find it in 3D Train Studio -> "Plugins" -> "Simulation" -> "MBS-Drehen-EV" and in this forum here...EASY
Hallo Nickel68,
Zitatvor 44 Minuten schrieb Nickel68:Allein 9 Wünsche von Trevor wurden gar nicht von unseren oben auftretenden englisch sprechenden Helfern beantwortet
... netter Versuch (der Provokation)... Du schreibst es ja selbst... es sind Wünsche.
Hast Du eine Antwort auf...
"Alle Fenster in der Größe einstellbar machen"
"Automatisches Nummerierung beim Kopieren und Einfügen"
"Baumstruktur für Variablenanzeige"
"Mehere Instanzen vom MBS zulassen"
"Sperren der y-Rotation auf 0 Grad"Dies sind sehr spezielle Wünsche, die das Programm betreffen... diese Fragen kann nur einer definitiv beantworten... und Neo nimmst solche Dinge (meist) still zur Kenntnis...
P.S. Prinzipiell läßt sich mit Zahlen vieles "belegen"... aber Zahlen haben nur in geeignetem Kontext eine (wahre) Aussagekraft...
Zitatvor 3 Stunden schrieb Neo:da das Forensystem aktuell keine spezielle Behandlung von mehrsprachigen Themen unterstützt, wäre die einzige Option im Moment, so wie früher einen eigenen englischsprachigen Bereich anzubieten.
... setze es einfach um... so schnell es geht !
EASY -
... ich habe nur eine Frage... (... an diejenigen, die hier nur in Deutsch lesen wollen...)
... was soll nun der englischsprachige Anwender
(der eben kein (/nur etwas) Deutsch kann und weiß, das bei google nicht unbedingt etwas verständliches herauskommt)ZitatAm 25.9.2016 um 20:25 schrieb HOKLBU:manche Texte werden dann auch noch vorher von "Mr. Google" übersetzt und entbehren jeder Logik.
denn nun nach Eurer Meinung tun???? ... und ich meine nicht, bis Neo eine "Lösung" hat... sondern jetzt aktuell !....
Zitatvor einer Stunde schrieb FeuerFighter:Da das Verhältnis inzwischen Englischs lastig ist, habe auch ich kaum noch Lust das Forum zu lesen.
... und das auch noch ohne, daß Euch "die Lust am Lesen" vergeht?
EASY -
Hallo Michael,
.... nur der Vollständigkeit halber... falls sich noch jemand dafür interessiert...
Die Express 2015 für Desktop Version geht (gerüchteweise) nur unter Windows 10 (es gibt da widersprüchliche Aussagen). Bei der Installation unter Windows 8.1 hatte ich allerdings Probleme.... mit der Commuity 2015 Version ging es problemlos (sogar auf meinem "alten" Rechner mit Windows 7)...
EASY -
Hallo quackster,
... Du hast doch hier auf der Oberfläche stehen "...und zur identifikation umbenennen" bzw. "alle gleisnamen wieder herstellen" (auf dem letzten Bild)
Ist das nur auf der Oberfläche und im Programm nicht implementiert?
EASY -
Hallo Tom,
... ich bin etwas verwirrt.... in Deinen anderen Einträgen im Forum erweckst Du den Eindruck, daß Du mit der Versuchsversion vom MBS arbeitest...
... wie hast Du denn diese installiert?Gruß
EASY -
Hallo MP-Gamers,
... schön, daß Du Dich "traust" Dich mit der Materie zu beschäftigen... ich bevorzuge mehr das "interaktive" Lernen (ohne Buch)..
... da ich schon etwas Erfahrung mit der Steuerschnittstelle habe... kann ich Dich in Deinem Bestreben auch noch etwas unterstützen.Gruß
EASY -
Hi Curt,
The definition of "Breite":
... so it is 90° to the setting direction.You distance "SX1-SX1a" is not correct (50.8 mm) (it is 46mm)
If you use "Gleisabstand messen" and put Sx1 and SX1a at the end of a lane the two ends of the tracks must be in one line....... and must have the same position in z.
... also your lanes are not realy parallel in z direction...
I tried this settings...
... and the distance of the segments are "correct".
And why this happens at the end...... you've already answered here by your own...
P.S. ... it would be great if we could make a translation together... thanks for this offer...
Hallo Michael,
... meine ersten Gehversuche mit der Steuerschnittstelle waren vor gut 4 Jahren mit "Autoit"... (damals allerdings noch ohne TCP)
... da bist Du schon ein ganzes Stück weiter mit VB5 als Grundlage...Gruß
EASY -
Hi Curt,
Hallo MP-Gamers,
... kurz und bündig ...ja.
Ich habe hier mal eine Vorlage erstellt bei der die Grundkommunikation über die Steuerschnittstelle implementiert ist (TCP über 2 Ports). (Visual Studo Express 2013).
Track Direction
in Technischer Support
Hi trevor,
... i wunder what you want do to with the track orintation...
