Leslie
Alle erstellten Inhalte von Leslie
  1. In the connected layout I wish to release my figure the direction right and backwards.depot.mbp Instead of MBS throws a dice and 5% release correctly 95% wrong. No solution if I change anything because next release flips directions and go wrong at 95% How settings I must use to get a good direction and state?
  2. I think I found: if any deferred action in progress while I edit something (eg. event control) so defer is obsolete due editing time then program asks save regardless of I edited anything. Then animations stop even I choose "no save". This is a program error.
  3. Leslie antwortete auf Leslies Thema in Anlagen
    Now game is fully playable, check it here:mese.mbp
  4. Leslie antwortete auf Leslies Thema in Anlagen
    Congratulations! I plan to create a catalogue item from my book - of course without this story but shall contain a full description of its working. With this anyone can create his own story. If you send me a good story or part of it then I will program it to book.
  5. Leslie antwortete auf Leslies Thema in Anlagen
    Sorry, this scene is not ready for now. Please add me some time, and move backwards until.
  6. Leslie antwortete auf Leslies Thema in Anlagen
    No, there is a bonus sheet at the back cover if you reach it. Be creative!
  7. Leslie antwortete auf Leslies Thema in Anlagen
    Every interactive element has outlined under mouse cursor. Machine can drag and tow (if ready to go).
  8. Leslie hat Thema erstellt in Anlagen
    Hello, in my childhood I had a folding story book. If you opened then 3d figures appeared. I loved this kind of book but never seen a copy with trains. I created such kind now. This is my first work such kind and app. 90% ready but playable already. Check this and give me suggestions if you wish. mese.mbp
  9. Is there a method to inactivate only one block (not on LUA) and not all the event?
  10. Leslie hat Thema erstellt in Feature-Wünsche
    Hello, the crane normally rotate object to the direction of destination at last. Please develop a switch to ignore this final rotate choosable at any operation. Because direction of object and destination maybe differs so final rotate may cause misdirect that object.
  11. I think figured it: I wish to relese all vehicles forward. But currently depot not working this way: any direction vehicle enters, the same (or opposite, programable) leaves it. So I wish a new depot feature: regardless of input direction vehicle released forward. Please develop it if possible.
  12. In this case immediately returns to depot at release. How to avoid this? Vehicle enters either normal direction or backward. Normal direction is working.
  13. Switch is good but sometimes need animation. For example flashing, speed change or running only part of it. I think no advantage to restrict currently working functions.
  14. Leslie antwortete auf Leslies Thema in Feature-Wünsche
    No. I heard it from other modeller too.
  15. Leslie antwortete auf Leslies Thema in Feature-Wünsche
    Planning is ok, not any problem. We wish sometimes to see them in simulation.
  16. Leslie hat Thema erstellt in Feature-Wünsche
    I think not only I wish... the all items (light bulb, camera, roads, depot etc) which currently disappear at simulation mode... maybe a switch to remain visible. Is it possible?
  17. Than change back from simulation to edit mode when you can select anything.
  18. Nearly everything can be solved the question is the cost. If it is too much than no advantage. This game seems to promising, you can check it soon. I am halfway now.
  19. This is a game. Vehicle stops at a point and must not move (forward) until condition fulfilled. If you move manually that ruin game. In other case vhicle stops, driver get out and do something then get in, back to saved position. If you move vehicle during this, than driver get in to wrong place! He can miss the train at all!
  20. For example in this case engine easily can be towed. This is good in some cases and not good in other cases depending on the story. I will publish this layout soon.
  21. Using Windows 10 in sleep mode currently running MBS program are completely shut off sound system until MBS program restart. All other function is normal and other windows sounds are also normal. Please check this case.
  22. If zero max speed is too hard to program than I suggest develop parking brake to absolute, ultimate brake. Not any moving with this brake.
  23. Hello, at simulation mode interactive devices are outlined. Also locked turnouts - but they are not interactive! So I think better not outline them to avoid confusing.
  24. I write a game when manual towing is base function at some cases.
  25. Thanks. Sorry for this. Can you say what is parking brake for? What is it do?
