Leslie
Alle erstellten Inhalte von Leslie
  1. Leslie antwortete auf Leslies Thema in Feature-Wünsche
    You are right, possible devices must remain hidden. Then I suggest: 1: Fix layer (for ex. 1) become visible at simulation. or 2: Properties of layer shows visibility at simulation. There are some things must this change and hard to switch always during editing.
  2. Leslie hat Thema erstellt in Feature-Wünsche
    During simulation mode please turn all layers to visible and switch back to original state at edit mode. In the "layers" window keep original display to check state. Thank you in advance.
  3. I have similar problem, I wish to adjust sound to speed. Finally using a timer based 0,2 sec but it is not the ideal solution. The 99% of time speed is constant, changes are within a few seconds.
  4. So this is the proper layut, I hope... I created a little show. Use view "0" to see it.vonat2.mbp
  5. So sorry, I am mismatched this. Never wanted to post this, excuse me. I will post proper layout again and forgive me for this.
  6. Please tell me what is forbidden in that layout.
  7. Drivers obey traffic lights also.traffic.mbp
  8. Right. But normally speed does not change too often. And in that cases you can use targetspeed which change much less (normally). If both changes too much that is wrong use of resources, need re-think all. Also current speed regulators follow exact changes and do not use too much resources.
  9. I also do not wish use such a quick timers. I much prefer proper events like speed change. It also be used for volume control.
  10. I think this program no need to work in background. Maybe other users have different thoughts so I suggest a switch at settings defaulted to "off" or "0 FPS". Thank you in advance!
  11. Leslie antwortete auf Leslies Thema in Anlagen
    Now you can RC any plane: airplane.mbp
  12. If it stops, normal "stop" event occurs. I am not programmed any event to this but watching.
  13. This is beautiful! But... 8 pc. is needed for a single cross: Using only black lines still needed 4 pc. of them. This is not affordable. I must seek for other solution.
  14. Under the given circumstances endless animations stop. This is hard to reproduce: - rotors etc. designed for endless work never stop. - animations not designed for endless loop can stop: like suit wearer (telefon animation). Canadair Jet CRJ 200 and all other similar planes can stop, but: turbines work properly. Positionlight and for eg. flugzeugnase can stop if you set to endless. Sorry, I can not determine circumstances. I watched for 2 weeks and only I know that you have to edit something in layout. Not this plane but anything. If you set 10 similar animations at different objects then all stops at once (and normal animations remain untouched) but I do not know which event stops them. What kind of problem is this?
  15. I trying to find a good cross at this situation: These 2 is the best so far but... they are not good I think. Do you know any better?
  16. Maybe a method: this forum. There is a name and password (and possible some time and publication number on this forum). If Neo thinks, he can accept this for upload layouts. It depends on his decision.
  17. Leslie antwortete auf Leslies Thema in Anlagen
    Added helicopters and animations. I plan create RC planes here. airplane.mbp
  18. 1. and 3. are welcome. 2. Automatic scaling is often problem to me, I will set it off. Unfortunately there is some object where it is unswitchable (always on) that causes serious problems. I create mixed layouts with different and permanent scaling.
  19. Leslie hat Thema erstellt in Anlagen
    This is a simple country airport with an international air show. airplane.mbp Press flip switch to start.
  20. I have a faint glow, this is not that house which I have seen previously. This house has normal inner structure, while the other has about 50 rooms in all floor. I can not find that house now.
  21. This is the problem: average house is empty while this house has inner structure. Look at it inside.
  22. Sorry, I do not understand this. Is this causes FPS loss or not?
  23. I discovered this house is full of empty, raw rooms. This is problem because of FPS. I suggest you decide either remove that rooms or make the inner structure of building (like doors), or both, at variations.
  24. Finally I hired a trained policeman. Law and order in all places... at least in the first rows. Drivers sometimes push cars from back. traffic.mbp
