Leslie
Alle erstellten Inhalte von Leslie
  1. Thank you, this is useful.
  2. I think the solution if the program shows number of current and layout maximum poligons at key F4. Then everybody can check the current load.
  3. Thank you, waiting for!
  4. Leslie hat Thema erstellt in Anlagen
    In my younger days we often deployed tracks in the house but never in the garden. Now I combined both. Enjoy the party! Arab.mbp
  5. Hello, @KÖNNYEN rotary control / tacho has 2 errors: - in deafult (300) variation only works correctly if max speed of vehicle also 300. If I select 100 for max, then controller shows this speed as 300, so real display is percent (%) not km/h. - all other variations plus has an error: for example if I select variation 100, then it shows max at 1/3 speed. So if I select 100 for max and variation 100, then it shows 100 (max) at real speed 33 and above. Can you correct this? This controller is the most perfect for shape.
  6. And control lights? These work like normal lights eg. index. This is an inner index light instead of outer.
  7. Hello, @Forgasd meg a Hummert I created a layout with your Scheduled Bus and I am very glad to use it. It has normal inner camera sight and this gave me a thought to create a real driving from inside. I deployed a speed controller and a door opener to cockpit (not original place for visibility).Please install this and control lights (index, brake, etc) for the modell as standard accessory if you wish. Can you interested?
  8. Leslie antwortete auf Leslies Thema in Feature-Wünsche
    Hello, I am learning this studio now. My old layout had ready for 1 day after 2 weeks (not published, only has nostalgic value - but it shows the possibility of this studio). Other layout, bus station finally also has conventional depots. I know the behaviour of portals for now and in that circumstances this is the best solution. But I always searching for better. I have seen about 25 systems while searching for this studio, and this is the best among them for me. My suggestions brings advance for this program and it means more modellers to come in and use this program with pleasure. For example inner sight is popular in more places and customers here sure shall glad with it. Also not much work, I think. But if something is too heavy to develop, like moving passengers in buses then I also delay it and make other things with more ease.
  9. Leslie antwortete auf Leslies Thema in Feature-Wünsche
    This method allows to switch vehicles between 2 separated tracks with only 2 portals instead of 4. I think this function is useful and not hard to develop. I think there is no reason to not develop something because it is not common now.
  10. Leslie hat Thema erstellt in Feature-Wünsche
    Hello, I wish a new function for portals. Currently they works random. I recommend use directions, like attached example program:portals.mbp Thank you in advance!
  11. This is inheritance, used in program languages. I also recommend this, greatly ease programming.
  12. Leslie antwortete auf Leslies Thema in Anlagen
    Update. Passengers still away.busz-pu.mbp
  13. A little update: drivers, passengers, train lights - and modellers.
  14. Here is the layout: busz-pu.mbp The event is "Enter park" and "Any obj var chg". If a vehicle has "Park = 1" variable then directed to and Enter park triggered in specific places.
  15. Leslie hat Thema erstellt in Anlagen
    Hello, I created a bus station of my hometown. This is my first more serious plan so any comments are welcome. Vehicles still move like trains, using turnouts. Next work I will use newer method. This is a draft, simplified plan and still no passengers. Press button "Schranke" twice to Morgen or Feierabend. busz-pu.mbp
  16. Hello, after a long, random defer execution the event "any object variable changed" has not triggered. Variable changes, OK. Placing before defer same command triggers correctly. After defer trigger missing: What happened here?
  17. Leslie hat Thema erstellt in Feature-Wünsche
    Hello, I suggest a new feature: the experience of driving in inner sight. This needs a built-in speed regulator and a proper (turnable) camera setting: Also in buses, where maybe door opener button and control lights, like index also available: I think this needs an easy way to attach this (or other) regulator to any vehicle modell by developer. These open a new horizons in driving. Thank you in advance.
  18. Hello, I am searching for an engine (train, bus) driver, who can stand or sit, using the cockpit (proper hand position) and can see around (has camera, which I can use). Like Dieter engine driver or Günter train driver by @SualokinK or bus driver by @fmkberlin These 3 in one person I can not find so long. Can you help for this?
  19. Hello, I found only 1 trolleybus in all collection but it is poor. But exist many buses which can solve as trolley... if it has a pantograph. So I wish an adjustable trolleybus pantograph which can be adjust to buses. Thank you, in advance.
  20. If a vehicle arrives my depot I send it to another. It is OK. But later I wish to send another vehicle from here to the same depot and using the current event. How to do this?
  21. This is not a problem, I need a customizable expansion. The signal can work like old method too. Or can be design new signal with new name and category. There is a modell in real life: PIKO signals (but I prefer bigger luminarie for visibility. Current size is all OK). I can not use 2* size because this overlay tracks.
  22. My program caused bad result. I thought that same variables (i, t) cause this. Later reorganized everything and now I have no nested iterations.
  23. Based on the advice of @Goetz the partial solution: Create a user-triggered event with parameter "Track": $("Events").variables["Truck"] = layout:getVehiclesOn(Track)[1] Then you find the first vehicle of given track on the module variable "Truck". Or nil if track is empty. You can use this event with any module or write it directly to LUA.
  24. In my case this is a useful effect. When my vehicle enters the depot, another leaves (on other depot). More realistic if it is not the same. Disadvantages: 1 vehicle remains in depot permanently until sg. directs it out.
  25. Thank you for developing this studio! Once a time I had a little, 2 * 1,5m H0 model railroad layout. I have a strong nostalgia for it and this studio can maximally fullfill this request. I created a very similar layout (2* bigger, better, more controlled, etc, etc) and I all satisfied for it. This studio has better solutions what I choosed for some cases but nostalgia factor directs me in develop. If you wish to start layout press big button and trains arrive. If all in work and you wish to re-pack them then switch hand-controlled turnout.
