hubert.visschedijk
Alle erstellten Inhalte von hubert.visschedijk
  1. Hello all/ Hallo alle The rotary Coal wagons (nickname "bathtub") are "ready" to be proved and availeble under ID number; BAAAEDFF-28D5-4195-81BC-8C5F901CF001 I say "ready", because if you want that i add the coals in the wagon and animated, i will try to make, in a beleiveble way. The texture for it i have added in the texture of the model, so there is the oportunity for it. with kind regards, Die Kohlekipperwagen (Spitzname "Badewanne") sind prüffertig und unter der ID-Nummer erhältlich; BAAAEDFF-28D5-4195-81BC-8C5F901CF001 Ich sage "fertig", denn wenn Sie wollen, dass ich die Kohlen in den Wagen füge und animiere, werde ich versuchen, es glaubwürdig zu machen. Die Textur dafür habe ich in die Textur des Modells eingefügt, also gibt es die Möglichkeit dafür. mit freundlichen Grüßen,
  2. Lovely ! Il ike the way how you have put the road higher and that stairs that leads up to it... so real ! You know you can adjust the distance from the crashbarriers to road itself, correct ? I mean, i you place the barrier next to the road and use the follow me tool... there is this adjustment you can make. If you place one, set it to the right distance, and then use the follow me tool again for the rest of the pieces of the road, the rest of the barriers will have the same distance as the first one you have placed (and configurated) (just recicicling info... you might allready know this) Perhaps i should allready upload some textures i edited on the basis of @BahnLandhis road textures, as an extra option in the MBS catalog. Dunno though how quick it might be available. I think @Neo is quite busy now with the V7 version. But then again, you can edit it yourself also, by exporting the texture, edit and re upload as a personel one. About the the white crash barriers. yes, they are from de faller roads. So those are white. By the way, your layout is European setup ? That road looks like a Dutch river side... very similar ! Gratz ! (could be German ) Or this one. Fresh... have a try. 375CA842-DD9A-4E38-9C9B-E5E63C9EC4AA And , have you tried these ? FB15B21B-B29A-4065-AA7C-0AC766030C9E These are from @FeuerFighter
  3. Wenn ich nur wirklich aufrichtig sein könnte.... einmal....
  4. Ich denke, es kann ein schönes Modell sein, mit einigen Unterschieden in den Basen. Von Neu über Renovierung bis Alt... BAAAEDFF-28D5-4195-81BC-8C5F901CF001 (Um die drehgestellen an zu schauen)
  5. Wunderbare anlage von @streit_ross! Das ist in der Tat die Idee, den Zug zu fahren und gleichzeitig die Waggons zu befüllen, langsam von einer Seite zur anderen. Und dann ist da noch die Tatsache, dass die Animation mit der Geschwindigkeit des Zuges erfolgen muss.... 0,7 km/h auf der anlage von streitross. Aber auch um den Wagen zu leeren, aber das ist eine andere Animation, eine Kippanimation... Ausreichend Denkstoff... Viele grusse
  6. Unglaublich intelligent, was du gemacht hast! Und das war eine meiner Bedenken, wie man das im Modell lösen kann. Die Kohletextur ist in der Haupttextur vorhanden, um etwas damit anfangen zu können. Ich selbst dachte an einen belebten Kohlenstrom, als würde er wirklich daraus fließen... Und auch zum Befüllen... aber dafür gibt es noch kein Ladegerät. Einer, der die Waggons belädt, während der ganze Zug langsam darunter durchfährt... Eine weitere Herausforderung, dies für den Wagen zu machen ... Ideen sind sehr willkommen, da ich sie noch nicht habe! Viele Grüße. (Alle Videos von dieses kanals sind übrigens sehr schön anzusehen!) https://www.youtube.com/channel/UCExmXPUzMVZnEu9b4sfDxFg
  7. Simon, that would mean i would have to redo everything.... But to explain the why... Since i didnt have the models of the wagons to start with (except my tankcars), i had to take the spots of the inlets of all the other cars, by using the basic cube from MBS to more or less measure it. So very well possible that with the more cars you line up, it will start to go off somewhere.. A simple solution for you to make whatever you want.... but it is a mock-up.... I edited a model to try to help. Save it, because i dont think it will make the catolog. C8ED44F4-9203-4A54-98C5-47838D406419 Have a try.
  8. Wegen des Popup-Fensters gehe ich davon aus, dass das Gesicht eine Gruppe ist. Machen Sie dies rückgängig und versuchen Sie es erneut, indem Sie mit der rechten Maustaste klicken und "projiziert" auswählen. Seien Sie nur sicher; Zuerst haben Sie ein einfaches fläche mit den gleichen Abmessungen wie die Textur entworfen. NICHT Größe. Dann "importieren" Sie die Textur als Textur auf diese Fläche. Nicht als Bild. viele grusse
  9. Hallo alle, / Hello all, Update zum Modell.... / Update on the model.... und beim zweiten BNSF-Modell hatte ich das falsche Logo hinzugefügt.. jetzt ist es richtig and on the second BNSF model i had added the wrong logo.. now its correct Viele grusse / With kind regards
  10. Simon Each oiloader conecter piece is to be used with its indicated cars. This is to have the animation work exactly on the inlets of the wagons. In the diferent model options you can see which car should be used with the model conector. On the picture below an example. Please follow up if there are any issues. With kind regards, Download this layout to have a look on a combination i have set up to see which piece is used where... Unfortenatly the inlet of the tankcar isnt exactly centralized. Thats why they all need to face the same direction, as you can see by the white stripes on the these cars. The newer tankcars, the shell etc, are centralized. So those you can place in whatever position. But from those the texture is also identical on both sides. 8C8B8A5E-02CA-4FA6-8C7A-A5DDC54FD0F0
  11. Weird way of painting... my opinion. Id import the texture on a face first and set it to projected. As of from slide 6 in the PPT Then start cutting out copies of that texture as shown in the slides afterwards. Can also be seen in the videos of Bahnland.
  12. One remark i didnt add in the PPT...
  13. Pete, the concrete ones ? Have a look under 97849D64-CE3D-4F61-9EC5-6E18F06EF029 But you can use this ones aswell as a concrete wall... Suggestion 159815A8-2E3A-43F1-8426-8050E4A1475E (without the ivy) or 554C63EC-6B2F-4AFB-9CD5-1B6312525B8F (no 2) And the metal ones 48E9212A-6616-4A2D-B3EB-4BED552B35C5
  14. Hallo zusammen, eine dritte Version wurde zum Testen hinzugefügt. Viele Grüße Hi all, a third version has been added for testing. Many regards
  15. Danke für Ihre Aufmerksamkeit! Sehr seltsam, da die richtige Oberfläche lackiert ist. Und schließlich ist es eine modifizierte Version des Hauptmodells. Wie auch immer, ich habe die beiden Innenseiten seiner Gruppen entfernt und zusammen gruppiert, damit SKP es als etwas Neues erkennt. Es ist jetzt gelöst. Danke noch einmal. Viele Grüße jedenfalls zur Erinnerung. Es gibt noch keine Rougness- und Metallic-Texturen, da ich immer noch an Texturen von anderen Firmen wie Norfolk Southern, CSX und anderen arbeite, die ich mit dem gleichen Modell gefunden habe.
  16. Ich würde es so belassen. Das ist eine gute Kopplung zu den anderen Spuren, auch wenn Sie mit ebene arbeiten, die Sie auf einer anderen Höhe als 0 konfiguriert haben. Top model ! Ich freue mich auf die Texturen, die Sie verwenden werden! ! viele grusse (Ich male mein Modell mit einer größeren Textur neu. Die Schrift an der Seite des Wagens wurde auf einem 1024 unlesbar. Ich habe jetzt auch eine PDN-Textur (paint-net) dafür gemacht, damit ich leicht andere Farben ändern kann, um auch andere Versionen mitzubringen. Da muss ich also schlau sein).
  17. Es ist typisch. Denn gestern habe ich mit DDS und PNG getestet. PNG war für mich schärfer als DDS. Gleiches Modell, gleiche Texturgröße... Viele grusse
  18. Dieses Modell sollte auch auf der Liste stehen. Vor allem, weil das drehgestell ein amerikanisches ist und ich es schon gebaut habe. (edited; nein. Meiner ist doch etwas anders aber kann erbaut werden von EMD70ACe) Aber das kann alles eine Weile dauern... die Liste hört nicht auf zu wachsen...
  19. Ich wäre nur ein kind.... jetzt alles anders hahaha Am 33:10 im video wirt gesagt auf Hollandisch "A front sein". Eine der Auflagen der DB damit die 1200 Waggons in Bentheim abholen konnten. Was ist das ? A front sein... habe nie davon gehört...
  20. Ich dachte immer, die 1200 sei eine "Bestie" groß mit einer unhöflichen frechen Erscheinung hahaha Spaß. Der Anfang des Films ist vom Bahnhof Utrecht. Der Zug mit der 1200 ist die Linie Amsterdam-Maastricht, gefilmt vom VIRM der Linie Rotterdam-Arnhem-Nijmegen. 1211 auch im berliner blau... interesant. Andere farbe... MIt Rheinhold wagonen..
  21. Was macht das für einen Unterschied? Könnten Sie mir das bitte erklären? Denn das interessiert mich gerade sehr. Viele Grüße.
  22. Ja, und jetzt muss ich noch die passende Lokomotive bauen... die 1100. Wenn ich mir dieses Foto anschaue, denke ich, dass das Berliner Blau etwas dunkler sein könnte. Aber ich sehe es durch das Bild... also könnte ich mich aus dieser Entfernung irren... Welche brücke ist das ? viel grusse
  23. Welcher Teil des Modells ist das?. ich erkenne es nicht....
  24. Vielen Dank für Ihre Aufmerksamkeit! Dies liegt daran, dass ich meine Anlag in MM konfiguriert hatte, die ich normalerweise in cm habe. Beim Importieren des Modells habe ich automatisch -3 eingegeben, während es zu diesem Zeitpunkt natürlich -30 sein musste. Es wurde bereits geändert und die Räder sind auf der Schiene nivelliert. Die Breite des Modells entspricht dem Bauplan, den ich zuvor gezeigt habe... Es wäre unrealistisch, das zu ändern... Viele Grüße.
