r4mir3zx Geschrieben 29. Dezember 2024 Geschrieben 29. Dezember 2024 Hi. First of all, many thanks for everyone who created this 3D Modellbahn Studio and contributed to it, created the wonderful models and shared them - and made my childhood dream possible. You are great, guys! This one is my third layout - ID is: 0410F16B-0CF7-42F8-BF40-BF4DB39373F0 - and the first one where I intended to experiment with the world building possibilities of the 3D Modellbahn Studio. On my first two layouts I mostly focused on developing the scripts that control eventually this one, too - so they mostly consisted of only tracks and the bare table, nothing that was worth sharing I think. "Winterification" was a pain, but the result is acceptable I think. Just don't look at the castle snow too close... Ah, and the pedestrian bridges have been carefully cleaned of the snow by the station crew ... (I wish I had at least a chamferbox primitive during creating the rooftop snows ... ) Just check the big lever switch on the right... The scripts are written in a general fashion - they work with object parametrization together - so that it can be used on any future layout with just dropping the scripts and setting up object parameters (signals, trains, tracks, etc). Hoewever I'm sure many of the solutions can still be refined. There's room for improvement. I tried to make sure a missing parameter won't break the working of the rest. I release tested it, but there can still be issues around... It's not fully automated, I usually like to tinker with the controls on other layouts, too. My favourite ones are those with the GBS controls on them where I can control stuff, that's what inspired me to build this one also with GBS controls. The route and GBS signal controls mostly work back and forth, though the GBS signals tend to leave routes turned on sometimes, I think I will have to work on that part still. During using the GBS to set the signals the selection of the route depends on the states of the turnouts that follow the signal. So if a signal doesn't want to set any route please check the turnouts after it. Though I think it's still better using the route dialog... Regarding the track plan: it's an old one that I created years ago in an other - much less capable - designer software. Discovering this MBS I wanted to figure out how it would look like in a more realistic setup, so recreated that old plan here. It also could be refined, can use a longer parade route, and/or a longer station, etc, but I wanted to remain as close to the original layout dimensions of 2.5m x 1.6m as possible. This is also the reason why the curves are a bit too tight. So I suggest not running longer trains than those already on the tracks - especially not on the branch line up to the castle where I had to use R1 curves. I hope you'll like it. Thanks for all the constructive criticism in advance. Happy New Year for all of you, have a nice, prosperous 2025! -------- PS.: Sorry, but currently I speak only in English, all that I know in German is what I learnt during working with this 3D MBS... so now I know right and left and such things, and also can count at least to 100... So this translation came from the google. PS.: Entschuldigung, aber derzeit spreche ich nur Englisch, alles, was ich auf Deutsch kann, habe ich bei der Arbeit mit diesem 3D-MBS gelernt … also kenne ich jetzt rechts und links und solche Dinge und kann auch mindestens bis 100 zählen … Diese Übersetzung stammt also von Google: -------- Hallo. Zunächst einmal vielen Dank an alle, die dieses 3D Modellbahn Studio erstellt und dazu beigetragen haben, die wundervollen Modelle erstellt und sie geteilt haben – und meinen Kindheitstraum möglich gemacht haben. Ihr seid großartig, Leute! Dies ist mein drittes Layout - ID: 0410F16B-0CF7-42F8-BF40-BF4DB39373F0 - und das erste, bei dem ich mit den Möglichkeiten des 3D Modellbahn Studios zum Erstellen von Welten experimentieren wollte. Bei meinen ersten beiden Layouts habe ich mich hauptsächlich auf die Entwicklung der Skripte konzentriert, die letztendlich auch dieses hier steuern – daher bestanden sie hauptsächlich nur aus Gleisen und dem bloßen Tisch, nichts, was es wert war, geteilt zu werden, denke ich. Die „Winterfestmachung“ war mühsam, aber das Ergebnis ist meiner Meinung nach akzeptabel. Schauen Sie sich den Schnee des Schlosses nur nicht zu genau an ... Ah, und die Fußgängerbrücken wurden vom Bahnhofspersonal sorgfältig vom Schnee befreit ... (Ich wünschte, ich hätte beim Erstellen des Dachschnees wenigstens ein Chamferbox-Primitiv gehabt ... ) Schauen Sie sich einfach den großen Hebelschalter rechts an ... Die Skripte sind allgemein gehalten – sie arbeiten mit der Objektparametrisierung zusammen –, sodass sie auf jedem zukünftigen Layout verwendet werden können, indem Sie einfach die Skripte löschen und Objektparameter einrichten (Signale, Züge, Gleise usw.). Ich bin mir jedoch sicher, dass viele der Lösungen noch verfeinert werden können. Es gibt Raum für Verbesserungen. Ich habe versucht sicherzustellen, dass ein fehlender Parameter die Funktion des Rests nicht beeinträchtigt. Ich habe es getestet, aber es kann immer noch Probleme geben ... Es ist nicht vollständig automatisiert, ich bastele normalerweise auch gerne an den Steuerelementen anderer Layouts herum. Meine Favoriten sind die mit den GBS-Steuerelementen, mit denen ich Dinge steuern kann. Das hat mich dazu inspiriert, dieses auch mit GBS-Steuerelementen zu bauen. Die Routen- und GBS-Signalsteuerung funktioniert größtenteils hin und her, obwohl die GBS-Signale dazu neigen, manchmal Routen eingeschaltet zu lassen. Ich denke, daran muss ich noch arbeiten. Wenn Sie das GBS zum Einstellen der Signale verwenden, hängt die Auswahl der Route von den Zuständen der Weichen ab, die dem Signal folgen. Wenn also ein Signal keine Route einstellen möchte, überprüfen Sie bitte die Weichen dahinter. Ich denke jedoch, dass es immer noch besser ist, den Routendialog zu verwenden ... Bezüglich des Gleisplans: Es ist ein alter, den ich vor Jahren in einer anderen – viel weniger leistungsfähigen – Designersoftware erstellt habe. Als ich dieses MBS entdeckte, wollte ich herausfinden, wie es in einem realistischeren Aufbau aussehen würde, also habe ich den alten Plan hier nachgebaut. Er könnte auch verfeinert werden, eine längere Paraderoute und/oder einen längeren Bahnhof usw. verwenden, aber ich wollte so nah wie möglich an den ursprünglichen Layoutabmessungen von 2,5 m x 1,6 m bleiben. Dies ist auch der Grund, warum die Kurven etwas zu eng sind. Ich schlage daher vor, keine längeren Züge fahren zu lassen als die, die bereits auf den Gleisen sind – insbesondere nicht auf der Nebenstrecke bis zum Schloss, wo ich R1-Kurven benutzen musste. Ich hoffe, es gefällt Ihnen. Vielen Dank im Voraus für alle konstruktive Kritik. Ein frohes neues Jahr Ihnen allen, haben Sie ein schönes, erfolgreiches Jahr 2025!
Goetz Geschrieben 29. Dezember 2024 Geschrieben 29. Dezember 2024 vor 21 Minuten schrieb r4mir3zx: "Winterification" was a pain, but the result is gorgeous! And the seasons switch is mighty clever!
r4mir3zx Geschrieben 30. Dezember 2024 Autor Geschrieben 30. Dezember 2024 Thanks much. It looked the most user-friendly this way. The alternative would have been to turn on and off layers - and actually it can still be done, season layers are labelled with "SUMMER" and "WINTER" prefixes, all others with no prefix should be visible all the time (except which should not, e.g. road control signals, though as I see they cannot be seen in simulation mode). Initially the toggle was also used to set up the keyword parameters for the script: e.g. I turned on the visibility for all winter objects only and toggled the switch, and with that the script set up all the visible objects with the "winterObject" keyword. Then did the same with the summer only ones and then I just had to comment out the setup code and write the one that turns visibility on/off based on the toggle switch state and that was all, it changes between summer and winter swiftly. There are less figures on the winter layout, because most characters wear inappropriate clothes for winter time (e.g. the girl called "Clara" , she reminds me Clara Oswald from Doctor Who) Also storks had to leave to the south and I thought the cows and the horse would not enjoy the winter cold, so just removed them, too ... At one point I looked for a polar bear in the dictionary but found no one unfortunately ... as well as also no mammoth nor penguins could be found... Also the summer background had to disappear. Though I found a winter background and it's quite nice, but for this layout I found its blue sky too bright ... I wanted something more cloudy, maybe with snow. And I tried out putting snow particles in the layout, too, but with some 2500 snow particles even my PC struggled to render it with an appropriate FPS, and such so eventually I decided not to include it. If any of you has a power PC with some high end graphics card then don't hesitate to put in a snowbox and let it snow, I bet it would look nice. --- Translated by google: Vielen Dank. So sah es am benutzerfreundlichsten aus. Die Alternative wäre gewesen, Ebenen ein- und auszuschalten – und das geht eigentlich immer noch, Jahreszeitenebenen sind mit den Präfixen „SOMMER“ und „WINTER“ gekennzeichnet, alle anderen ohne Präfix sollten immer sichtbar sein (außer denen, die es nicht sein sollten, z. B. Straßenkontrollsignale, obwohl diese, wie ich sehe, im Simulationsmodus nicht sichtbar sind). Ursprünglich wurde der Umschalter auch verwendet, um die Schlüsselwortparameter für das Skript einzurichten: z. B. schaltete ich die Sichtbarkeit nur für alle Winterobjekte ein und schaltete den Schalter um, und damit richtete das Skript alle sichtbaren Objekte mit dem Schlüsselwort „winterObject“ ein. Dann machte ich dasselbe mit den reinen Sommerobjekten und dann musste ich nur noch den Setup-Code auskommentieren und den Code schreiben, der die Sichtbarkeit basierend auf dem Zustand des Umschalters ein-/ausschaltet, und das war alles, es wechselt schnell zwischen Sommer und Winter. Es gibt weniger Figuren im Winterlayout, da die meisten Charaktere für den Winter unpassende Kleidung tragen (z. B. das Mädchen namens „Clara“, sie erinnert mich an Clara Oswald aus Doctor Who). Auch die Störche mussten in den Süden ziehen und ich dachte, die Kühe und das Pferd würden die Winterkälte nicht mögen, also habe ich sie auch entfernt ... Einmal habe ich im Wörterbuch nach einem Eisbären gesucht, aber leider niemanden gefunden ... und auch Mammuts und Pinguine waren nicht zu finden ... Auch der Sommerhintergrund musste verschwinden. Ich habe zwar einen Winterhintergrund gefunden und er ist ganz nett, aber für dieses Layout fand ich seinen blauen Himmel zu hell ... ich wollte etwas Bewölkteres, vielleicht mit Schnee. Und ich habe auch versucht, Schneepartikel in das Layout zu setzen, aber mit etwa 2500 Schneepartikeln hatte sogar mein PC Probleme, es mit einer angemessenen FPS darzustellen, und so habe ich mich letztendlich dazu entschieden, es nicht aufzunehmen. Wenn jemand von euch einen Power-PC mit einer High-End-Grafikkarte hat, dann zögert nicht, eine Schneebox hineinzustellen und es schneien zu lassen, ich wette, das würde gut aussehen.
r4mir3zx Geschrieben Freitag um 19:28 Uhr Autor Geschrieben Freitag um 19:28 Uhr Hi, good evening everyone, Happy New Year! I played a bit with the layout and noticed some issues here and there, with the grounds, or with the bus line and I decided to fix them. After fixing them I thought it would also be nice to have some quick buttons to access train cameras. I had set up cameras originally to see how they handle the curves and such, so they had already been there. What I just needed were some buttons and a quick script to handle them - you can find the new camera buttons under the bus line automation button. Afyer setting up a camera I also recalled how other people used buttons on their GBS lines to activate routes. So I decided to do something similar: I again dropped in a quick script and parametrized buttons to quickly activate (or deactivate) some pre-defined routes. Those buttons can be found on the middle GBS control group. When you activate it it will highlight the selected - and activated - route on the GBS controls. While the button stays in an active state the routes will be activated again and again. Toggling the buttons off will turn off the pre-defined route sequence, too. CW buttons are for clockwise routes, CCW are for counter-clockwise routes. Please note: not all the possible route sequences are handled by those buttons - some routes have to be selected manually! Also added some train drivers, at least to the two green electric locomotives. Finally, I decided to add a new signal house next to the western level crossings - that part was so empty, it needed something and comparing my layout with the original 12-year one plan I found there a signal box placed. So I put one here, too. I hope I won't find more issues. ------- Translated by Google Translate: -------- Hallo, guten Abend allerseits, frohes neues Jahr! Ich habe ein bisschen mit dem Layout gespielt und hier und da ein paar Probleme bemerkt, mit dem Gelände oder mit der Buslinie, und ich habe beschlossen, sie zu beheben. Nachdem ich sie behoben hatte, dachte ich, es wäre auch schön, ein paar Schnelltasten zu haben, um auf Zugkameras zuzugreifen. Ich hatte Kameras ursprünglich eingerichtet, um zu sehen, wie sie mit Kurven und dergleichen umgehen, also waren sie schon da. Was ich nur brauchte, waren ein paar Tasten und ein schnelles Skript, um sie zu handhaben – Sie finden die neuen Kameratasten unter der Buslinienautomatisierungstaste. Nach dem Einrichten einer Kamera erinnerte ich mich auch daran, wie andere Leute Tasten auf ihren GBS-Linien verwendeten, um Routen zu aktivieren. Also beschloss ich, etwas Ähnliches zu tun: Ich fügte wieder ein schnelles Skript ein und parametrisierte Tasten, um einige vordefinierte Routen schnell zu aktivieren (oder zu deaktivieren). Diese Tasten finden Sie in der mittleren GBS-Steuerungsgruppe. Wenn Sie sie aktivieren, wird die ausgewählte – und aktivierte – Route auf den GBS-Steuerungen hervorgehoben. Solange die Taste in einem aktiven Zustand bleibt, werden die Routen immer wieder aktiviert. Wenn Sie die Schaltflächen ausschalten, wird auch die vordefinierte Routensequenz deaktiviert. CW-Schaltflächen sind für Routen im Uhrzeigersinn, CCW für Routen gegen den Uhrzeigersinn. Bitte beachten: Nicht alle möglichen Routensequenzen werden von diesen Schaltflächen verwaltet – einige Routen müssen manuell ausgewählt werden! Außerdem wurden einige Lokführer hinzugefügt, zumindest für die beiden grünen Elektrolokomotiven. Schließlich habe ich beschlossen, neben den westlichen Bahnübergängen ein neues Stellwerk hinzuzufügen – dieser Teil war so leer, dass etwas fehlte. Als ich mein Layout mit dem ursprünglichen 12-Jahres-Plan verglich, stellte ich fest, dass dort ein Stellwerk platziert war. Also habe ich auch hier eines platziert. Ich hoffe, ich werde keine weiteren Probleme finden.
r4mir3zx Geschrieben Freitag um 19:32 Uhr Autor Geschrieben Freitag um 19:32 Uhr Ah, yes, forgot to mention the predefined cameras from 0 to 6, some of my favourite views. Some of those screenshots above are from them. I hope you'll also like it. Kind Regards --- Google Translate: --- Ach ja, ich habe vergessen, die vordefinierten Kameras von 0 bis 6 zu erwähnen, einige meiner Lieblingsansichten. Einige der Screenshots oben stammen von ihnen. Ich hoffe, es gefällt Ihnen auch. Mit freundlichen Grüßen
Goetz Geschrieben Freitag um 19:48 Uhr Geschrieben Freitag um 19:48 Uhr vor 15 Minuten schrieb r4mir3zx: I hope you'll also like it. A lot, yes!
r4mir3zx Geschrieben Freitag um 19:53 Uhr Autor Geschrieben Freitag um 19:53 Uhr Ah, and I almost forgot it again to mention something about routes and train activation: the trains don't have to be at the signal contact to be started. For all the starter signals there's a sequence of tracks defined as "StarterTracks". On any signal or route activation any trains with engine (hasEngine) on those starter tracks will be started. I tried to set up starter tracks up to a distance where the train driver still can "see" the signal. That's usually the 5 or 6 tracks before the signal, well, depending also on length and such. Usually turnouts are not included, but sometimes they are. This is a small layout... There are special cases however: Certain locomotives, like e.g. BR 81 has a different local coordinate system setup than those of the rest. For that case a "RotationOffset" number should be added to the locomotive variables with the rotation with which the train coordinate system is offset to that of the world's. E.g. in case of BR 81 it is 90 degrees, so "RotationOffset" should be 90. This is because when I worked with the scripts I had some problems with the methods that determine train direction, so I wrote my own that decides whether train stands in the direction of the signal or not (currently there's a hardcoded 30 degrees tolerance, can maybe be even less...). ------- Translated by Google Translate: -------- Ah, und ich hätte fast wieder vergessen, etwas über Fahrstraßen und Zugaktivierung zu erwähnen: Die Züge müssen nicht am Signalkontakt sein, um loszufahren. Für alle Startsignale gibt es eine Reihe von Gleisen, die als „StarterTracks“ definiert sind. Bei jeder Signal- oder Fahrstraßenaktivierung werden alle Züge mit Lokomotive (hasEngine) auf diesen Startgleisen losgefahren. Ich habe versucht, Startgleise bis zu einer Entfernung einzurichten, in der der Lokführer das Signal noch „sehen“ kann. Das sind normalerweise die 5 oder 6 Gleise vor dem Signal, na ja, je nach Länge und so. Normalerweise sind Weichen nicht enthalten, aber manchmal schon. Dies ist ein kleines Layout … Es gibt jedoch Sonderfälle: Bestimmte Lokomotiven, wie z. B. BR 81, haben ein anderes lokales Koordinatensystem als die anderen. Für diesen Fall sollte den Lokomotivvariablen eine „RotationOffset“-Nummer mit der Rotation hinzugefügt werden, mit der das Zugkoordinatensystem gegenüber dem der Welt verschoben ist. Z. B. bei BR 81 sind es 90 Grad, also sollte „RotationOffset“ 90 sein. Das liegt daran, dass ich beim Arbeiten mit den Skripten einige Probleme mit den Methoden hatte, die die Zugrichtung bestimmen, also habe ich meine eigenen geschrieben, die entscheiden, ob der Zug in Richtung des Signals steht oder nicht (derzeit gibt es eine fest codierte Toleranz von 30 Grad, kann vielleicht sogar noch weniger sein...).
Herman Geschrieben Samstag um 11:33 Uhr Geschrieben Samstag um 11:33 Uhr (bearbeitet) Hello @r4mir3zx , your layout is just super. Greetings, Herman ( BE ) Bearbeitet Samstag um 11:34 Uhr von Herman
r4mir3zx Geschrieben Sonntag um 18:15 Uhr Autor Geschrieben Sonntag um 18:15 Uhr On 1/4/2025 at 12:33 PM, Herman said: Hello r4mir3zx , your layout is just super. Greetings, Herman ( BE ) Thanks much! It wouldn't be super without the hundreds of models you guys all created and shared and I learnt much also from the layouts that you all had submitted before. Playing with this is like being in a shop with full of model trains that are just all mine to play with... and there's nothing to break, no short circuit, etc Endless possibilities here. --- Vielen Dank! Es wäre nicht so toll ohne die Hunderte von Modellen, die ihr alle erstellt und geteilt habt, und ich habe auch viel von den Layouts gelernt, die ihr alle zuvor eingereicht habt. Damit zu spielen ist wie in einem Laden voller Modelleisenbahnen zu sein, mit denen ich einfach spielen kann ... und nichts kann kaputtgehen, es gibt keinen Kurzschluss usw. Endlose Möglichkeiten.
Goetz Geschrieben Sonntag um 18:52 Uhr Geschrieben Sonntag um 18:52 Uhr Hello @r4mir3zx, Am 3.1.2025 um 20:53 schrieb r4mir3zx: I had some problems with the methods that determine train direction There is a condition vehicle is heading toward a track/trackcontact which maybe you could use to determine the direction? The Lua equivalent would be this method: if vehicle:isHeadingToward($("example signal 1")) then -- perform action end Please note that I used a signal in my example. That's possible because it has a dedicated contact. You may also use any other contact. Or specify a track piece. Kind regards Göetz
r4mir3zx Geschrieben Sonntag um 19:43 Uhr Autor Geschrieben Sonntag um 19:43 Uhr 20 minutes ago, Goetz said: if vehicle:isHeadingToward($("example signal 1")) then -- perform action end Yes, I think that was the method I tried. And as I remember - it was a month ago or so - initially it looked like working, but then for some reason it just didn't. And since I had already written my own version, instead of debugging I think I just decided to go with my one. Now I don't know whether I broke something in my script when I applied the isHeadingToward() or something else was the cause of the confusion. There's a chance that it was just before I found those vehicles with the different local coordinate setup (like BR 81 or DB 212 - their local X axis is pointed sideways and the Y axis is what points to their vector of motion) ... But I'll try out again that method and will see what caused the issue. Maybe it was just me confusing things --- Ja, ich glaube, das war die Methode, die ich ausprobiert habe. Und soweit ich mich erinnere – es war vor etwa einem Monat – sah es zunächst so aus, als würde es funktionieren, aber dann hat es aus irgendeinem Grund einfach nicht funktioniert. Und da ich bereits meine eigene Version geschrieben hatte, habe ich mich, glaube ich, einfach für meine eigene entschieden, anstatt sie zu debuggen. Ich weiß jetzt nicht, ob ich etwas in meinem Skript kaputt gemacht habe, als ich isHeadingToward() angewendet habe, oder ob etwas anderes die Ursache für die Verwirrung war. Es besteht die Möglichkeit, dass es kurz bevor ich diese Fahrzeuge mit den unterschiedlichen lokalen Koordinateneinstellungen gefunden habe (wie BR 81 oder DB 212 – ihre lokale X-Achse zeigt seitwärts und die Y-Achse zeigt auf ihren Bewegungsvektor) ... Aber ich werde diese Methode noch einmal ausprobieren und sehen, was das Problem verursacht hat. Vielleicht habe ich einfach nur Dinge verwechselt.
Goetz Geschrieben Sonntag um 20:02 Uhr Geschrieben Sonntag um 20:02 Uhr vor 16 Minuten schrieb r4mir3zx: then for some reason it just didn't. Wouldn't it be nice to figure out what some reason actually was? Certainly saves you a lot of hazzle when you get it to work again, doesn't it? And there are users here who'd be happy to help you figure out the cause of the hiccups.
r4mir3zx Geschrieben Sonntag um 20:39 Uhr Autor Geschrieben Sonntag um 20:39 Uhr Yeah, you are right Goetz! That's what I've just done Here is the changed script (btw I changed it on my test layout to see things clearly, the script is exactly the same as on the Vorsuchstadt layout): And the effect: Initially the BR 86 refused to be started, saying that it was not heading toward the signal R01-01_Enter. Unfortunately I didn't create a screenshot from that. Then I swapped it with BR 81 which happily started running around, so it was definitely found by the isHeadingToward. So I thought it's actually the way around and the sideways X local coordinate setup is the correct for the train. Proof that it worked, you can see the happy huffs and puffs of the train there: Now I changed back to BR 86 and to my greatest surprise it worked, I did some runs around but isHeadingToward returned "true" for that at the R01-01_Enter signal. I changed to another engine, BR 144, just to see what's going on, it has again X coordinate in the direction of travel, contrary to BR 81. And it again worked. At this point I got confused as it didn't work initially with BR 86. Now after some rounds with BR 144 I stopped it at a signal in a curve, at signal R01-05_R04-04_Enter. Then I allowed it to enter the "station", and when I wanted to restart it I got this: I think the reason is deeper than I can see currently. It's like some heisenbug or mandelbug. Regards, r4mir3zx --- Ja, du hast recht, Götz! Das habe ich gerade gemacht. Hier ist das geänderte Skript (ich habe es übrigens auf meiner Testanlage geändert, um die Dinge klarer zu sehen, das Skript ist genau dasselbe wie auf der Vorsuchstadt-Anlage): Bild 1 Und die Wirkung: Zunächst weigerte sich die BR 86, gestartet zu werden, mit der Begründung, sie fahre nicht auf das Signal R01-01_Enter zu. Leider habe ich davon keinen Screenshot gemacht. Dann habe ich sie mit der BR 81 vertauscht, die fröhlich losfuhr, also wurde sie definitiv von isHeadingToward gefunden. Also dachte ich, es ist eigentlich umgekehrt und die seitliche lokale X-Koordinateneinstellung ist die richtige für den Zug. Als Beweis dafür, dass es funktioniert hat, können Sie das fröhliche Schnaufen und Pusten des Zuges hier sehen: Bild 2 Nun bin ich wieder auf BR 86 umgestiegen und zu meiner größten Überraschung hat es funktioniert. Ich habe ein paar Runden gedreht, aber isHeadingToward hat dafür am Signal R01-01_Enter „true“ zurückgegeben. Ich habe auf eine andere Lokomotive, BR 144, um zu sehen, was los ist, gewechselt. Sie hat wieder die X-Koordinate in Fahrtrichtung, im Gegensatz zu BR 81. Und es hat wieder funktioniert. An diesem Punkt war ich verwirrt, weil es anfangs mit BR 86 nicht funktioniert hat. Nun, nach einigen Runden mit BR 144, habe ich sie an einem Signal in einer Kurve angehalten, am Signal R01-05_R04-04_Enter. Dann habe ich sie in den „Bahnhof“ einfahren lassen und als ich sie neu starten wollte, bekam ich dies: Bild 3 Ich glaube, der Grund liegt tiefer, als ich derzeit erkennen kann. Es ist wie ein Heisenbug oder Mandelbug. Grüße, r4mir3zx
r4mir3zx Geschrieben Sonntag um 20:49 Uhr Autor Geschrieben Sonntag um 20:49 Uhr (bearbeitet) Hm, at least I am able to reproduce it now consistently with stopping first at the curve and then continuing. Whenever it stops at the curve at R01-05_R04-04_Enter and I set the signal free there it returns 'false' but still starts the engine, and then it fails eventually at R01-01_Enter. Strange. So this is why I went with my solution on the Vorsuchstadt layout. --- Hm, zumindest kann ich es jetzt konsistent reproduzieren, indem ich erst an der Kurve anhalte und dann weiterfahre. Immer wenn es an der Kurve bei R01-05_R04-04_Enter anhält und ich dort das Signal freigebe, gibt es „false“ zurück, startet aber trotzdem den Motor, und dann versagt es schließlich bei R01-01_Enter. Seltsam. Deshalb habe ich mich für meine Lösung auf dem Vorsuchstadt-Layout entschieden. Bearbeitet Sonntag um 20:51 Uhr von r4mir3zx
r4mir3zx Geschrieben Sonntag um 20:59 Uhr Autor Geschrieben Sonntag um 20:59 Uhr Oh, OK, I just figured it out why it started still the engines at the curve when I set that R01-05_R04-04_Enter free: it stopped at the contact point and the signal had been set to automatically accelerate it. If it stops way before the contact point on any of the starter tracks, it cannot be started, because the isHeadingToward() returns false then. I just don't understand why then it returns also false in the straight track? (BTW in the straight track the signal R01-01_Enter is not set to accelerate trains automatically. ) --- Oh, ok, ich habe gerade herausgefunden, warum die Motoren in der Kurve noch gestartet wurden, als ich R01-05_R04-04_Enter freigab: Es hielt am Kontaktpunkt an und das Signal war so eingestellt, dass es automatisch beschleunigte. Wenn es auf einer der Startstrecken weit vor dem Kontaktpunkt anhält, kann es nicht gestartet werden, weil isHeadingToward() dann false zurückgibt. Ich verstehe nur nicht, warum es dann auch auf der geraden Strecke false zurückgibt? (Übrigens ist das Signal R01-01_Enter auf dem geraden Gleis nicht so eingestellt, dass es Züge automatisch beschleunigt.)
r4mir3zx Geschrieben Sonntag um 21:15 Uhr Autor Geschrieben Sonntag um 21:15 Uhr (bearbeitet) What I did in my method - you can see them in the commented out lines - was to find the track on which the locomotive was standing and then calculated a vector from the center of that track to the center of the next one (the _previous_ starter track in the StarterTrack list of the signal*) pointing towards the signal. Then compared the angle between this vector and the locomotive's own one heading forward and if the angle is below a certain value (that is hardcoded to 30 degrees now but can be smaller actually) then the train was considered as "startable". This also has the benefit of working in curves, even when the locomotive's vector is still pointing significantly away from the signal. Of course I took into account the direction of the train, too. * In the StarterTracks list the closest track to the signal is the first and so on. --- Was ich in meiner Methode gemacht habe - Sie können es in den auskommentierten Zeilen sehen - war, das Gleis zu finden, auf dem die Lokomotive stand, und dann einen Vektor von der Mitte dieses Gleises zur Mitte des nächsten (des _vorherigen_ Startgleises in der StarterTrack-Liste des Signals*) zu berechnen, das auf das Signal zeigt. Dann habe ich den Winkel zwischen diesem Vektor und dem der Lokomotive in Vorwärtsrichtung verglichen, und wenn der Winkel unter einem bestimmten Wert liegt (der jetzt fest auf 30 Grad codiert ist, aber tatsächlich kleiner sein kann), wurde der Zug als „startfähig“ betrachtet. Dies hat auch den Vorteil, dass es in Kurven funktioniert, selbst wenn der Vektor der Lokomotive noch deutlich vom Signal weg zeigt. Natürlich habe ich auch die Richtung des Zuges berücksichtigt. * In der StarterTracks-Liste ist das dem Signal am nächsten gelegene Gleis das erste und so weiter. edit: grammar Bearbeitet Sonntag um 21:16 Uhr von r4mir3zx
r4mir3zx Geschrieben Sonntag um 21:26 Uhr Autor Geschrieben Sonntag um 21:26 Uhr (bearbeitet) Aaand I figured it out: when the locomotive stands exactly on the signal's contact, the isHeadingToward() returns false. Actually it works well in the curves, too. In case when the signal is not set to auto-accelerate on setting it free, like in case of signal 'R01-01_Enter' the train does not start because then neither the signal nor the script can start it. Actually it's logical, it's not isHeadingToward it is already on the contact. -- Uuund ich habe es herausgefunden: wenn die Lokomotive genau auf dem Kontakt des Signals steht, gibt isHeadingToward() false zurück. Tatsächlich funktioniert es auch in den Kurven gut. Wenn das Signal nicht so eingestellt ist, dass es beim Loslassen automatisch beschleunigt, wie im Fall des Signals „R01-01_Enter“, fährt der Zug nicht los, weil dann weder das Signal noch das Skript ihn starten können. Eigentlich ist es logisch, es ist nicht isHeadingToward, es steht bereits auf dem Kontakt. Bearbeitet Sonntag um 21:47 Uhr von r4mir3zx
r4mir3zx Geschrieben Sonntag um 22:00 Uhr Autor Geschrieben Sonntag um 22:00 Uhr So conclsion: adding "or engine:isLocatedOn(currentSignal)" to the condition can help Have a good night, I go to sleep. --- Fazit: Das Hinzufügen von „or engine:isLocatedOn(current Signal)“ zur Bedingung kann hilfreich sein. Gute Nacht, ich gehe jetzt schlafen.
r4mir3zx Geschrieben Sonntag um 22:46 Uhr Autor Geschrieben Sonntag um 22:46 Uhr (bearbeitet) Well, though however, now I see isHeadingToward() returns true even when the train direction is set to point away from the signal. Does it not take into account the vehicle direction? Seemingly it doesn't: I really go to bed now, good night! --- Nun, jetzt sehe ich jedoch, dass isHeadingToward() „true“ zurückgibt, auch wenn die Zugrichtung so eingestellt ist, dass sie vom Signal weg zeigt. Berücksichtigt es nicht die Fahrzeugrichtung? Anscheinend tut es das nicht: Bild 1 Ich gehe jetzt wirklich ins Bett, gute Nacht! Bearbeitet Sonntag um 23:08 Uhr von r4mir3zx
Phrontistes Geschrieben gestern um 00:33 Uhr Geschrieben gestern um 00:33 Uhr vor 1 Stunde schrieb r4mir3zx: Does it not take into account the vehicle direction? Seemingly it doesn't: Switching the driving direction does not change the IsHeading. This only happens after the vehicle starts moving in the opposite direction.
r4mir3zx Geschrieben gestern um 07:52 Uhr Autor Geschrieben gestern um 07:52 Uhr 6 hours ago, Phrontistes said: Switching the driving direction does not change the IsHeading. This only happens after the vehicle starts moving in the opposite direction. Wow, thanks! Exactly, and I could reproduce it: Which is a bit of head-scratching, since then how could it be decided whether after starting a motionless train it would head toward a certain signal or not? Also desctiption of the isHeadingToward() does not mention that the train should be moving when it's called: Well, after thinking a bit: if in case of a motionless train the isHeadingToward() decides based on the positive driving axis (let it be either X or Y) direction consistently, then it can be figured out using the vehicle's .drivingDirection. Something like: local vehicleIsHeadingTowardSignal = vehicle:isHeadingToward(currentSignal) if vehicle.drivingDirection == -1 and vehicle.acceleration == 0 and vehicle.speed == 0 then vehicleIsHeadingTowardSignal = not vehicleIsHeadingTowardSignal end Looks a bit weird, though, all those checks to make sure it does not move ... However on this layout as well as on the Versuchstadt layout my original method has had no such problems with deciding train direction since the last change in... I don't know maybe mid-November. So I think - at least for now - I keep it rather than using isHeadingToward(). Regards --- Wow, danke! Genau, und ich konnte es reproduzieren: Bild 1 Das ist ein bisschen rätselhaft, denn wie könnte dann entschieden werden, ob ein stehender Zug nach dem Losfahren auf ein bestimmtes Signal zufährt oder nicht? Außerdem erwähnt die Beschreibung von isHeadingToward() nicht, dass der Zug fahren sollte, wenn es aufgerufen wird: Bild 2 Nun, nach kurzem Nachdenken: Wenn im Falle eines stehenden Zuges isHeadingToward() konsequent basierend auf der positiven Richtung der Fahrachse (sei es X oder Y) entscheidet, dann kann es mithilfe der .drivingDirection des Fahrzeugs herausgefunden werden. So etwas wie: Code hier Sieht allerdings ein bisschen komisch aus, all diese Prüfungen, um sicherzustellen, dass es sich nicht bewegt ... Auf dieser Anlage sowie auf der Versuchstadt-Anlage hatte meine ursprüngliche Methode jedoch seit der letzten Änderung in ... ich weiß nicht, vielleicht Mitte November, keine derartigen Probleme mit der Entscheidung über die Zugrichtung. Ich denke also – zumindest vorerst –, dass ich es behalte, anstatt isHeadingToward() zu verwenden. Grüße
