220hotwheels
Alle erstellten Inhalte von 220hotwheels
  1. Hi Goetz Dobby's back I've followed your example, I feel sure accurately. I've even tried my magic wand but all to no avail. If the lights are on green then vehicles go, if on amber then they go but a bit slower, if on red and amber they wait and if on red they stop but clearly they only do so providing I change them manually. Nothing works automatically. The only element that I have not used is the "random destinations" as the two vehicles on this test junction are set on a fixed course. Surely this is not my problem!! Clearly I am missing the magic dust needed kick start the auto element but I haven't been able to find it yet. Might I therefore intrude on 'Dumbledore' once more for what I hope to be final guidance on the element. I have attached the relevant mbp file which I hope will enable you to point out the errors of my ways. Kind regards Pete (Dobby) traffic light test layout.mbp
  2. If I didn't know better I would think you had a camera installed in my study. How else could you possible come up with such an accurate analogy!!
  3. Good morning Goetz The demo is absolutely great, many thanks for that. It makes abundantly clear what I was lacking in my attempt to copy your initial instructions and so today will hopefully see my first junction performing smoothly. As everywhere there are always bad drivers, perhaps I will have to introduce traffic police with speed cameras and impose heavy fines on such bad behaviour!!!! Impatience in all walks of life today has become the norm and that includes me when trying to learn something new with this hobby. I have duly reprimanded myself for such bad behaviour. Many thanks once again. Pete
  4. Hi Goetz I've managed to work through your suggested solution and watched the video, which despite the language element was most informative and the instructions were very easy to follow, great video. This now brings me to the final bit, the switch. What is this connected to? There are two elements that will allow a connection, the car and the traffic light opposite the side junction. I have tried both and neither provides any change in the traffic lights. Clearly I am missing something but not really sure what. Pete
  5. Hi Douglas I've taken a quick look at the file you sent me and it does look as though it would be easy to follow so many thanks for that. Goetz has also sent me a reply with a detailed explanation as to what I need to do. I am going to try to work through his system first and then move on to yours. Hopefully by working through both I will learn just a little more and end up with a better understanding which I'm sure will assist me with other elements of my EV. As you probable noted from my unfinished Fairmont layout my EV needs more than just a little help. By the way since V7, Fairmont has gained a holiday island, Sandown, which can be reached via a tunnel system under what I have named Fairmont Sound. I do so enjoy the construction bit, it's the EV part getting things to work properly that I keep putting off. Anyway many thanks for taking the trouble to provide me with a solution, it is greatly appreciated. Pete
  6. Yet more learning this evening. That's great, thanks. I'll give it a try now. Pete
  7. Hi Goetz As you rightly stated, it's not good to assume anything even if at the time it sounds logical. Your example above seems to be just the ticket, so to speak, I have only one extra small favour to ask. Would it be possible to provide a larger screen shot of your EV please. I can almost follow the one above but not too sure on one or two bits. Old eyesight does have it's drawbacks!! I'll let you know how I get on over the next day or so. Pete
  8. HI Douglas Just taken a good look at the demo you sent me. Whilst it may well solve issues with general junctions for later I cannot figure out how to adapt it for traffic light control. Perhaps I'm missing something, you know me, at times a lead short of a pencil!!! Pete
  9. Hi Douglas That's brilliant, many thanks. I'll take a look in the next hour and get back to you if I have any questions. My attempt thus far has got the vehicles to stop on red and go on green just so long as I operate the traffic lights manually, not really ideal. I'll get back to you later. Pete
  10. Hi Everyone To many of you the question that I am about to ask will probably have a very simply and maybe obvious answer but I am afraid to me it does not. The basic principle would seem to be relatively logical but putting that into practice is proving to be less straightforward. I wish to set up a traffic light system to control road vehicles. Whilst my layout has many complicated junctions generated in V6 I have concluded that if I can sort out the basics for one simple 'T' junction using V7 components then all of the rest will follow even if it means redoing all other junctions. My conclusion thus far is to assume that control comes in two parts. The first to set the traffic lights to change from red to amber/green or visa versa. This I assume would be done in the form of a timer so that the two lights on the main road would be "connected" and therefore work simultaneously with the one controlling the traffic from the side road changing in reverse to the other two but still at the same time. Part two, I assume, is to tell the respective vehicles to stop or start at the appropriate time using a suitable variable. If the basic principle is right then I am at somewhat of a loss as to just how to achieve this in EV. I've looked through and tried various options but so far got no where. Any guidance that anyone can offer would be most appreciated but please keep said advice as simple as possible, assume you are dealing with a complete novice when it comes to EV work. I have attached a screenshot of the junction involved Kind regards Pete
  11. Good morning to both Goetz and Simon Having slept on the above problem I concluded that I should remove the roundabout and replace it with a crossroads in an effort to see if that solved the problem of not being able to produce a complete round trip route that would provide a trouble free route for my bus. It has worked, eureka, and whilst that problem is solved it still begs the question why does the roundabout cause this issue? A problem for another day I think. Pete
  12. Hi Simon and @Goetz Thanks for the additional information. It will prove to be most useful when I eventually get to that point. For now I continue with my struggle to solve the basics. Having spent all of last night working diligently through the route for my bus I did find that some of the road sections had nor converted over properly from V6 to V7 and so with the help of a spreadsheet I was able to check each section, methodically, and correct those that were not quite right. Having done so I was able to set a complete route from start to finish. However as there is a roundabout involved I found that the bus would negotiate the roundabout OK on it's way out but on it's return it got confused as to just which way to go. My solution was to set the route in two halves. A route out and a route back. In order to set the second part I found it necessary to delete the last waypoint for out route. With the return route set I waited for the bus to return to it's start point, which it did and stopped in the bus station for it's allotted time as per the E.M. All once again seemed fine. The bus set off once more on it's journey but as soon as it encountered the first junction, the one back into the bus station, it simply selected that route and returned. I have included screenshots that I hope will help to explain this. I have looked at the junction itself and it is set at '0' which should send the bus nicely on it's way. I first encountered this problem whilst the return route was highlighted in green and therefore deleted the final waypoint for that section, the stop contact in the bust station. Clearly there is something else that I need to do in order to complete and secure this route but at present I cannot figure it out. Any thoughts please. Kind regards Pete
  13. Hi Douglas You should know me by now!! "Two feet into the pond Pete" is my nickname. I have always taken the view that the quickest way to learn anything is to jump in at the deep end, make all the mistakes imaginable and as you start to put them right then the solution sinks in quicker. Perhaps it is not the most scientific way, it certainly isn't the best use of time but then I have plenty of the latter. I will now move forward with the advice from Goetz and hope that I get my bus to completing it's round trip without too many disgruntled passengers!!! Yes I have included passengers in the bus this time, the bus tickets are much cheaper than those for the train!! kinr regards Pete
  14. Brilliant. Many thanks for that. The drawing board awaits once again. The lack of a detailed manual is more than made up by you guidance, I just don't like to bother you or other members if I can avoid it. Many thanks Pete
  15. Hi Goetz and @simonjackson1964 Perhaps I am overthinking setting waypoints, or perhaps I am simply missing the point of what constitutes a junction but thus far I have been unable to complete my circular route. The aim is to set a route for a bus from point A to B, C and then return to A. The route itself is quite involved and covers some distance. I can get from A to B to C and begin the return to A having only selected 4 track contacts (waypoints or junctions) I'm not sure. However as soon as I try to select another TC the route is lost and I am told there are too many junctions. What is just a little frustrating is the fact that of the so called 3 remaining "waypoints or junctions" to make up the so called 7 I would only need 2 to get back to my start point. Having completed the route up to point C I have then selected apply to see if that helps, which I assume saves the route but if I then try to continue from that point I simply delete all of the previous route. I am sure I would not be alone in saying that the most difficult part of learning this hobby is the lack of a detailed manual. That said I do fully understand the difficulties that producing such a document might entail. I recently bought a new Samsung smartphone, which came without any manual whatsoever. Much of the aspect of said phone are fairly straightforward to follow but to get the best out of it I decided to work through the manual, all 168 pages which I had to download. Having done so I have been able to learn much more about the phone and to remove all that I do not want whilst tweaking aspects that I do want. Anyway back to my current problem. I hate to take up anymore of your time but I would really appreciate an additional pointer in order to get me started on redoing much of my road functions. Sort out one round trip route and all others will follow in time. Kind regards Pete p.s. to Simon, your advice sounds most logical and as Goetz has already commented 'a smart approach'. I might be able to take advantage of it in a month or so !!!
  16. Once again many thanks for that. The first option is clear and fully understood. The second might take me a little longer to fully understand but time is a great teacher so I'll sort out the first option as priority one and the second one in the fullness of time. Kind regards Pete
  17. A most sensible approach, thank you. I have one further question if I may. The destination route is shown in green when the vehicle to follow that route is highlighted. When the vehicle is not highlighted the destination route does nor appear. I assume therefore that the initial control of the vehicle is within the E.M. I note that for the trains the orange route only appears when the actual route is chosen in the routes list but there is no such lists for vehicle and their destinations. Kind regards Pete
  18. Hi Goetz Your description is not confusing at all. Many thanks for clarifying this point. Since posting my question I had begun to play around with the little target icon but in conjunction with the route also. I did eventually get to my destination but I think it was very much by chance rather than good management. I will now go back to the beginning and do it properly. One point that did keep coming up was an error message saying that there were, "too many junctions", I think that was it. No doubt I have been trying to do too much in one go so hopefully my next attempt will be somewhat more professional and successful. Many thanks Pete
  19. Hi Having spent some time getting to grips with the new elements of scenery properties with V7 I have started to try to understand other elements and have begun with setting a simple road journey from point A to point B. Setting the actual route seemed straightforward enough and all seemed to be going well until I encountered a roundabout. As can be seem from the screenshot the route is clearly highlighted but as soon as a vehicle enters the roundabout it immediately heads for the first exit and ignores the given route. I have looked through some of the video's posted in an effort to see if I can find a solution but thus far all in vein. For my sins I regret I cannot speak German and whilst it is almost possible to follow the progress on the video the finer detail is somewhat lost as I cannot fully understand either the spoken word or follow too closely the drop down E.M elements. Anyway if I can solve one problem then it might just provide the solution to ongoing problems with these new routes and so if any of you very knowledgeable members can shed light on the solution to my immediate dilemma I would be very grateful. Kind regards Pete
  20. Hi Neo Knuckles duly wrapped if I have jumped the gun but after only a very brief glace through V7 I have to say that it seems to have surpassed all expectations. Great improvement on V6, brilliant. I'm sure there are many like me who will put up with the fixes to follow element just to be able to explore the new version. Kind regards Pete
  21. Hi to all my fellow enthusiasts. The long awaited V7 version is now available so for those interested in the upgrade here is a link that will get you started. https://community.3d-modellbahn.de/wiki/allgemein/%C3%BCbersicht-%C3%BCber-die-neuen-funktionen-v7-r33/ Enjoy. I'm sure I will, from a brief glance there are some amazing treats in store. I only hope those with larger layouts such as mine have been accommodated. Only time will tell as I work through all of the goodies. Pete
  22. Hi Hubert Once again many thanks for at least considering this for a potential future build. I fully understand that it is not a priority but just a small seed for possible future consideration. Kind regards Pete
  23. @hubert.visschedijk Hi hubert As promised I have put together a few photo's for you to consider. I fully understand there is no obligation on your part and even if you were to consider producing anything along these lines it is likely to be well into the future, so many, many thanks for even considering this request. Kind regards Pete
  24. Hi Hubert Everything with me is usually by luck rather than good management, but hey if it works, no problem. Kind regards Pete
  25. Hi Simon Many thanks for both of your replies. I assume Douglas will pick these up and comment further. This is not something that I am currently involved with but no doubt in the future I have this as a reference point. Kind regards Pete
