arnyto
248 -
Beiträge erstellt von arnyto
Am 6.8.2021 um 03:27 schrieb Dad3353:
Excellent, Hubert; I've got it working, but a part of the issue has been a misunderstanding on my part. I thought that the Custom textures should show up as a drop-down list, in the same way as the Variant. This is not the case, as I now realize; one simply has to select the file required and the texture is applied. In fact, it seems that, as long as the texture file is '_Custom', the rest is either ignored or not used, and one may select any picture file at all; MBS will apply it to the model. Here's a picture (the cover of a guitar method book; not even multiple of binary ² dimensions, and MBS drapes it over the model.
I found that only the '_Custom' declaration is needed; the others never appear anywhere. I'm surprised, but it's working, so that's a Good Thing. As long as there's a declaration of '_Custom.png', any picture file can be used. I don't know if this is normal, but it works ..!Excellent, Hubert; I got it working, but part of the problem was a misunderstanding on my part. I thought the custom textures should show up as a drop down list, just like the variant. This is not the case, as I now realize; All you have to do is select the file you want and the texture will be applied. In fact, it seems that as long as the texture file is '_Custom', the rest is either ignored or not used, and one can choose any image file; MBS applies it to the model. Here's a picture (the cover of a guitar textbook; not even a multiple of ² binary dimensions, and MBS drapes it over the model.
I've found that only the '_Custom' declaration is needed; the others do not appear anywhere. I'm surprised, but it works, so that's a good thing. As long as there is a declaration of '_Custom.png', any image file can be used. I don't know if this is normal, but it works ..!hello @Dad3353how are you? what s news about the famous train? do you need help or info?
Gerade eben schrieb arnyto:
Hello yes i totally understand, i said that because your wagon is the only in the game with this animation, and it s very cool to see him full and empty.
and i will love have some rocks, ballast train with this kind of animation
Am 14.8.2021 um 13:48 schrieb hubert.visschedijk:
No.
Because they are ROTARY COAL WAGONS. And build only for the purpose of coal transport in the USA
Ballast wagons are other type of wagons, like on the picture that you have posted here.
With kind regards,
vor 14 Stunden schrieb hubert.visschedijk:
The rock version is being made.
with kind regards
Cool, thanks, if you have time can you do a "ballast" version or if we can upload the textur of your creation i can do several version and after i give to everyone here the different version i will create.
thanks
hello @hubert.visschedijk what a gret job again!! A question is it possible ti create a verison with ballast or rocks inside, a full verison.
And this possible to export the textur file to create some dirty version or other?
thnaks a lot
hello @Dad3353 what a good job! I upload the model in the game to see and inside the cockpit we can see the back of the outside texture. I think you can create a cockpit wall or maybe there is an option thanks again and tell me if i can help.
vor 13 Stunden schrieb Dad3353:
Thanks, both. With this precious information, I was able to quickly transform the SNCF (again, unfinished business, but it's a start...) ...
Danke, beide. Mit diesen wertvollen Informationen war ich in der Lage, die SNCF schnell umzugestalten (wieder noch unerledigte Angelegenheiten, aber es ist ein Anfang...) ...
I'll have to revise my method for the DD currently causing me problems, to enable a single 'wrap-around' texture. Currently I'm using the 'paint-pot' palette technique, but I may be able to convert. I still need to work out these 'normal' issues, of course.
Ich muss meine Methode für die DD, die mir derzeit Probleme bereitet, überarbeiten, um eine einzelne "Wrap-Around" -Textur zu ermöglichen. Derzeit verwende ich die Palettentechnik "Paint-Pot", aber ich kann möglicherweise konvertieren. Diese "normalen" Probleme muss ich natürlich noch lösen.
Hello, i m very happy to read the last messages! If you want when you have publish the model, i can create different textur version qith the textur file. And after i give it to everyone!
hello a another good model @Dad3353, If it's possible can we modify the textur file when it will be in the game, it will be vrey classy and i can create another textur and version.
And please don t stop creating the french model
Am 24.7.2021 um 18:52 schrieb Dad3353:
Good evening, Herman...
I'm quite a beginner in train modelling, and enjoy the challenge of learning how to do things. I was disappointed in the response to these models, which, to me, could serve as a base for improvement and modernisation. I would like to attempt an experiment, to upgrade the first of these models (ID : A9AA3DCA-C4EB-4DB8-9094-43496094B901...). Would you be willing to share your source file, in whatever format you use, and allow me to try to bring the model up to modern standards (moving parts, reduced polygons, fitted interior etc...). I do have Sketchup 2017, but didn't get very far with it, and now use Blender, but I can convert from most file formats (I did this for the SNCF Regiolis; here's a picture of my version ...
Hoping this request meets with your satisfaction; meanwhile...Keep well, stay safe.
Guten Abend, Hermann...
Ich bin ein ziemlicher Anfänger in der Modellierung von Zügen und genieße die Herausforderung, Dinge zu lernen. Enttäuscht war ich von der Resonanz auf diese Modelle, die mir als Grundlage für Verbesserungen und Modernisierungen dienen könnten. Ich würde gerne ein Experiment versuchen, um das erste dieser Modelle zu aktualisieren (ID: A9AA3DCA-C4EB-4DB8-9094-43496094B901...). Wären Sie bereit, Ihre Quelldatei in jedem von Ihnen verwendeten Format zu teilen, und erlauben Sie mir, zu versuchen, das Modell auf moderne Standards zu bringen (bewegte Teile, reduzierte Polygone, angepasste Innenausstattung usw.). Ich habe Sketchup 2017, bin damit aber nicht sehr weit gekommen und benutze jetzt Blender, aber ich kann von den meisten Dateiformaten konvertieren (ich habe das für die SNCF Regiolis gemacht; hier ist ein Bild meiner Version ...
In der Hoffnung, dass diese Anfrage Ihrer Zufriedenheit entspricht; in der Zwischenzeit...Bleiben Sie gesund, bleiben Sie gesund.
Douglas
vor 14 Stunden schrieb HWB:
Hallo arnyto,
für die Modelle liegt mir noch keine Erlaubnis des Modellbauers vor, also nur für den eigenen Gebrauch.
Hallo Modellbahnfreunde,
mir liegt jetzt die Erlaubnis von Arman.Y vor seine Modelle weiterzugeben
Gruß Hermann
Ok, if you want i can send him an email to ask him, or you prefer ask him directly?
thanks again
hello @HWB i just want to know if these models on your pictures are free to ply on the game, because i like that
thanks a lot
@Dad3353 here you can find some help and keep going!!
@Dad3353 i love this tain I hope your can progress on this beautiful conception!! I can t wait to play with this in the game
@maxwei bravo bravo bravo!!!!!!
vor 2 Stunden schrieb maxwei:
Hello @maxwei Your version is better i see that this Traxx got a lot of delivery! I see the captrain and many more
Thanks again for your creation! It's not a french model but i like it
https://railcolornews.com/wp-content/uploads/Bombardier-TRAXX-DC_Captrain-253-103_Railcolor-News_3032.jpg?w=640
Hello everyo,e and congratulations @maxwei for your new beautiful model!!
It s a real pleasure to have the possibility to create some new skin and i have already do i quick test for fun
vor 3 Stunden schrieb HWB:
Hallo arnyto,
der Zug war nur als Entwurf hochgeladen um Probleme zu finden.
Entwürfe werden nach einiger Zeit wieder entfernt, dann bekommst Du diese Fragezeichen
Gruß Hermann
ok so i have to wait a final version to put in the game? I already miss this train
Am 26.5.2021 um 14:35 schrieb HWB:
Hallo Modellbauer,
da mir jetzt die schriftliche Erlaubnis von Lardman aus dem Sketchup Warenhaus vorliegt seine Modelle zu veröffentlichen
hatte ich mir als erstes den Class vorgenommen.
jetzt ist mir aufgefallen, das er in V6 beim anfahren auseinander reisst in V5 ist alles ok
ich habe ihn mal als Entwurf in V6 hochgeladen
Class+223+City+Voyager+CrossCountry 1
8DFD5940-2D79-4297-B700-29D1F4CCDEE5Class+223+City+Voyager+CrossCountry 2
DF83B3BD-FF08-48DD-9041-A3F9BE1BCCB6Class+223+City+Voyager+CrossCountry 3
76EAD3D7-7C5F-4BCF-9469-DD9002720832Class+223+City+Voyager+CrossCountry 4
D7948E63-7F5F-4701-8295-A6C09F0B71A4Class+223+City+Voyager+CrossCountry Drehgestell
F90F54B2-D213-4DC0-8F3A-AA81997F79F4Gruß Hermann
hello today the modela of city voyager are gone!it s normal?
Am 11.6.2021 um 00:06 schrieb David Teide:
Auto Express Terminal and Platadorma DMA9500 Car Car Carrier.
The image shows how the vehicles have been loaded onto the wagon and the 303 tractor will proceed to couple it to the express train.
Terminal von "Auto express" und Platadorma DMA9500 Car carrier.
Auf dem Bild sehen Sie, wie die Fahrzeuge in den Waggon eingestiegen sind und die Zugmaschine 303 den Waggon an den Schnellzug ankoppeln wird.Hello @David Teide what a beautiful car loading!!!! I'm looking for that wagon for a long time!! Do you want to share with us on the MBS? I will love ad it on my project! thanks again and very good job again!
Hello everyone, today i read that the Regiolis @Dad3353 is now testing on german and french line https://www.alstom.com/sites/alstom.com/files/styles/large_media_cover/public/2021/05/17/TFA%20picture%201.jpg?h=c6980913&itok=I2FGff2j
vor 2 Stunden schrieb HWB:
Bonjour constructeur de modèles,
depuis que j'ai maintenant l'autorisation écrite de Lardman au magasin Sketchup pour publier ses modèles
J'avais planifié le cours en premier.
Maintenant, j'ai remarqué qu'il se déchire en V6 au démarrage, en V5 tout va bien
Une fois, je l'ai téléchargé en tant que brouillon dans V6
Classe + 223 + City + Voyager + CrossCountry 1
8DFD5940-2D79-4297-B700-29D1F4CCDEE5Classe + 223 + City + Voyager + CrossCountry 2
DF83B3BD-FF08-48DD-9041-A3F9BE1BCCB6Classe + 223 + City + Voyager + CrossCountry 3
76EAD3D7-7C5F-4BCF-9469-DD9002720832Classe + 223 + City + Voyager + CrossCountry 4
D7948E63-7F5F-4701-8295-A6C09F0B71A4Classe + 223 + City + Voyager + CrossCountry Bogie
F90F54B2-D213-4DC0-8F3A-AA81997F79F4Salutations Hermann
hello @HWB what a great news! Thanks! I have a novice question, it is possible to give the access to modify the textur or it s impossible? Tanks again for the portage on the game
MSTS Modelle im MBS
Wouaw nice!!! and we can have it on the game? thanks
