525 -
Beiträge erstellt von henricjen
Hi Brummi, @Roter Brummer
Your recent work on the RhB locomotives have inspired me to return to model creation for the RhB I missed the community and making models...
First I need to update the flatwagon Lb 7852 and 5 containers with contact points. But I have encountered a problem, I hope you will provide me with a solution to, since you have just launched the great new 20 containers with contact points.
1) I have no problems adding and getting the container contact point to attach to a wagon that supports it. Like your Sp - w 8250. (Back track on picture)
2) But when I move the wagon, my container stays stationary, while your container correctly stays in position on the moving wagon.
How do I technically specify the container as a cargo, which attaches and stays with the wagon position?Happy new year and thanks in advance,
Henrik
Dear all,
merry Christmas and the wish for a most happy new year to all
Best regards,
Henrik -
Dear Max,
the wishes for a wonderful Christmas and a most happy new year.
Best regards,
Henrik -
Hi Brummi,
at present time, I am not doing more models for MBS. Time simply does not allow me that fun but time-consuming work anymore.
Kind regards,
Henrik -
Hi all,
finally using MBS v8, I have started a new narrow-gauge layout. It tells the thematic tale of a small stream flowing from the high mountain melting snow to the wast lake in the hills.
Displaying changing landscapes, the higher we ascend, and changing seasons for the most visual diversity.
First previews are of the lake city, the first of 5 modules nearly ready, displaying the narrow-gauge end station with standard-gauge connection. From here, only the narrow-gauge railway can bring you along the stream, tell its tales, and all the way up to the skiing resorts.
Kind regards,
Henrik -
Very sad news. All thoughts and prayers to Lothars family...
Respectful regards,
Henrik -
Hallo Norbert,
Hier ist das Problem. Die Hintergründe, die ich hinzufügen möchte, müssen zuerst im Online-Katalog veröffentlicht werden, damit alle sie in Layouts verwenden können, die sie in den Online-Katalog hochladen möchten.
Natürlich kann ich die Hintergründe in Photoshop für meine eigene Verwendung in einem lokalen Layout zuschneiden, aber das wird mir (oder anderen) nicht erlauben, das Layout mit intakten Hintergründen in den Online-Katalog hochzuladen. Sie werden leere "Changing scenery"-Panels ohne Textur sein, wie in Ihrem schönen Demo-Layout, da sie nicht im Online-Katalog zu finden sind.
Um die ursprüngliche x/y-Skalierung der Hintergründe beizubehalten, enden sie in einem 8x1-Format. 8x breit, 1x hoch.
Manchmal muss man nur einen 4x1 oder 2x1 Hintergrund für kürzere Längen oder Seiten/Ecken eines Layouts ausfüllen. Dann kann man die Textur nicht in der y-Achse komprimieren, ohne sie völlig zu verzerren.
@NeoThat das ist, warum ich sowohl die 8x1 und 4x1 (2 Hälften), um den Hintergrund Online-Katalog hinzufügen möchten. Mehr Flexibilität, weniger verzerrte Hintergründe.
Siehe 1 für 4x1 Ecke (1 Hälfte) Hintergrund.
Siehe 2 für 8x1 Ecke (voll) Hintergrund.
here is the problem. The backgrounds I want to add have to published to the online katalog first, so all can use them in layouts they want to upload to online katalog.
Of course I can just crop the backgrounds in Photoshop for my own usage in a local layout, but that will not allow me (or anyone else) to upload the layout to the online katalog with intact backgrounds. They will be empty "Changing scenery" panels without the texture, as in your nice demo layout, since they are not found in the online katalog.
In order to keep the original x/y scaling of the backgrounds, they end in a 8x1 format. 8x wide, 1x high.
Sometimes you need to just fill a 4x1 og 2x1 background for shorter lengths or sides/corners of a layout. Then you cant compress the texture in the y axis without distorting it completely.
@NeoThat is why I want to add both the 8x1 and 4x1 (2 halves) to the background online katalog. More flexible, less distorted backgrounds.
See 1 for 4x1 corner (1 half) background.
See 2 for 8x1 corner (full) background.
Hallo Brummi,
ich wusste nicht, dass es diesen gekrümmten Spline für Hintergründe gibt. Er macht ein gekrümmtes Flächenelement weitgehend überflüssig. Ich muss die Veröffentlichung in meiner Abwesenheit verpasst haben, vielen Dank für deine Arbeit und die Informationen.
Aber es zeigt die Textur immer noch in ihrer vollen Breite an und kann die Textur nicht beschneiden, wie es eine Ebene kann. Ich glaube, das ist ein Argument, das ich @Neo vorbringen werde, um zu versuchen, meine hochgeladenen 8x1 und 4x1 Hintergründe genehmigt zu bekommen. Aber in vielen Fällen kann dieser Spline-Hintergrund verwendet werden.Mit freundlichen Grüßen,
Henrik -
4 hours ago, norbert_janssen said:
Moin Henrik
ich habe auch mal Hintergruende ausprobiert !
Beschreibung in Anlage !
_norjan
Hallo Norjan,
ich warte immer noch auf eine Entscheidung von Neo bezüglich der "halb" breiten Hintergründe. Deshalb musste ich den obigen Beitrag an Neo schreiben, um meine Idee zu erklären. Es ist also noch nichts veröffentlicht...
Ich persönlich würde gerne eine echte 45- und 90-Grad-Kurve sehen, so wie Du sie in Deinem Testlayout gezeigt hast. Ich denke nicht, dass ebene Meshes die Lösung sind, da sie nicht aus der Proportion heraus neu skaliert oder beschnitten werden können.
I am still awaiting a decision from Neo regarding the "half" width backgrounds. Thats why I had to make the above post to Neo to explain my idea. So nothing is published yet...
Personally I would like to see a real 45 and 90 degree curve primitive as you have shown in the test layout. I dont think the solution are plane meshes, since they can not be rescalled out of proportion or cropped.
Kind regards,
Henrik -
Documentation for you regarding the additional half width background sections I have uploaded. And the mail answer I have sent you...
1 and 2: Traditional large y scaling of inverse backgrounds (only full width main and inverse 8x1 versions available) to fit corner.
3 and 4: Usage of the additional 4x1 textures (Main, inverse 8x1 and all 4 half versions 4x1 available) to reduce y scaling issue.
Kind regards,
Henrik -
Looks great @BahnLand
I am especially impressed by the quality of the texturing on the bogies...
Kind regards,
Henrik -
@maxweiHallo Max,
ich möchte dir die bestmögliche Genesung von diesem schweren Unfall wünschen. Du bist ein sehr geschätztes Mitglied dieser Gemeinschaft und du bereicherst uns alle durch deine Aktivität in den Foren.
Hochachtungsvoll, Henrik
Hi Max,I want to wish you the very best possible recovery from such at hard deal. You are a most valued member of this community and you enrich us all by any level of activity on the forums.
Respectfully, Henrik
A very nice module with great atmosphere
Hallo alle,
ich bin gerade dabei, dem Gllmghs 37 "Stuckgut Schnell verkehr", dem speziellen 2-Tandem-Wagenset, den letzten Schliff zu geben.
Mir ist bekannt, dass @SualokinK eine Version im März 2022 veröffentlicht hat, aber ich habe zuvor über 3 Monate im Jahr 2021 an diesem Projekt gearbeitet und bin nie dazu gekommen, dem Modell den letzten Schliff zu geben und es zu veröffentlichen. Daher hoffe ich, dass SualokinK mir verzeihen wird, dass ich meine Version auch veröffentliche.
Veröffentlichung noch ein paar Wochen entfernt...Mit freundlichen Grüßen,
Henrik---
Hi all,
I am putting the finishing touches to Gllmghs 37 "Stuckgut Schnell verkehr", the special 2 tandem wagon set.
I am aware that @SualokinK have published a version in March 2022, but I have previously been working on this project for over 3 month in 2021 and never got to put the final touches to the model work and publish it. Therefore I hope SualokinK will forgive me that I do publish my version too.
Publishing a few week away...
Kind regards,
Henrik -
Liebe Leute,
ich habe meine SerieA von 3D-Blattbäumen um spätsommerliche Versionen mit dunklerem Blattgrün erweitert. Die ursprünglichen Sommerversionen waren sehr hellgrün und sahen daher eher wie Frühlingsbäume aus.
Sie können die neuen Versionen in der ersten Reihe des ersten Screenshots sehen. Der zweite Screenshot zeigt alle jetzt verfügbaren Versionen 5: Sommer, Spätsommer, Herbst, Winter und Winter mit Schnee.
Henrik---
Dear all,
I have expanded my serieA of 3D leaf trees with late summer darker leaf green versions. The original summer versions were very light green and therefore more looked like spring season trees.
You can see the new versions in the first row of the first screenshot. The second screenshot shows all versions 5 available now; Summer, late summer, autumn, winter and winter with snow.
Kind regards,
Henrik -
Hi @norbert_janssen, got a bunch more backgrounds coming. Also most of the very US theme specific ones. But I have startet with preparing the ones that have a more location generic character and therefore more useful for European layouts. And the ones with most scenic qualities.
Regarding transparent sky backgrounds, please do see my answer earlier in the thread to Roter Bummer (Edited Thursday at 02:32 PM by henricjen)
Kind regards,
Henrik -
2 hours ago, norbert_janssen said:
Hi Henric
how can I get this backgrounds ?
Why you don't put the URL in your post like many others do ?
@Dad3353 indeed gave you the reason for the backgrounds not being available yet. They are awaiting approval by the sharp eye of Neo Thank you Dad3353!
I do not provide direct codes to them, since these are not drafts where you ask the community for input to an alpha or beta version. They are release versions that await release to the final online catalog. And that can happen any minute Neo presses the "release" button
Dad3352 hat euch tatsächlich den Grund genannt, warum die Hintergründe noch nicht verfügbar sind. Sie warten auf die Genehmigung durch das scharfe Auge von Neo! Danke Dad3353!
Ich stelle keine direkten Codes zur Verfügung, da es sich nicht um Entwürfe handelt, bei denen man die Community um Input für eine Alpha- oder Beta-Version bittet. Es sind Release-Versionen, die auf die Freigabe für den endgültigen Online-Katalog warten. Und das kann jede Minute passieren, wenn Neo den "Release"-Knopf drückt -
5 hours ago, Roter Brummer said:
Hallo Henric,
die Hintergründe gefallen mir sehr gut.
Was würdest du von Variationen halten, bei denen der Himmel vorsichtig weg retuschiert ist? Das würde die Einatzmöglichkeit multipliziern, da man dann auch mehrere Hintergünde miteinander kombinieren kann.
BrummiHello Henric,
I like the backgrounds very much.
What would you think of variations where the sky is carefully retouched away? That would multiply the typesetting possibilities, as you can then combine several backgrounds.
BrummiHi @Roter Brummer,
I think this a good idea to mask away the "sky" in another version. But that adds a lot of work to each image, because this masking has to be done very precisely in Photoshop to achieve a good result avoiding artifacts between sky and landscape contour. Right now my focus would be to add more backgrounds with sky and when that work is done, it certainly could be a project to provide many of them with "no sky"
Secondly I personally like them with the appropriate sky included. This due to the fact that the state of the sky matches the general light displayed on the landscape. For example that a sunny sky means many sunbeam highlights in the landscape, a cloudy sky adds partial shadows to the landscape and a sunset sky add orange colors to the landscape.
If you change the sky separately, it becomes less harmonic overall as a background.
But a good idea and I will address it later
Ich halte es für eine gute Idee, den "Himmel" in einer anderen Version wegzumaskieren. Aber das bedeutet eine Menge Arbeit für jedes Bild, da diese Maskierung in Photoshop sehr präzise durchgeführt werden muss, um ein gutes Ergebnis zu erzielen und Artefakte zwischen Himmel und Landschaftskontur zu vermeiden. Im Moment würde ich mich darauf konzentrieren, mehr Hintergründe mit Himmel hinzuzufügen, und wenn diese Arbeit abgeschlossen ist, könnte es sicherlich ein Projekt sein, viele von ihnen mit "keinem Himmel" zu versehen.
Zweitens mag ich persönlich sie mit dem entsprechenden Himmel. Das liegt daran, dass der Zustand des Himmels dem allgemeinen Licht entspricht, das in der Landschaft zu sehen ist. Ein sonniger Himmel bedeutet zum Beispiel viele Sonnenstrahlen in der Landschaft, ein bewölkter Himmel fügt der Landschaft partielle Schatten hinzu und ein Sonnenuntergangshimmel fügt der Landschaft orange Farben hinzu.
Wenn man den Himmel separat verändert, wird er insgesamt als Hintergrund weniger harmonisch.
Aber eine gute Idee und ich werde sie später aufgreifen
Kind regards,
Henrik -
Thema Rhätische Bahn - RhB
in Modelle
Hi Brummi,
the devil is in the detail. Here the correct name after the "_CP_"!
Thank you so much for the assistance and really looking forward to your ABe 4/4 II
My next project (after contact point updates) and updating myself on using Blender 4, will properly be some additional freight wagons. Staring with the Gb 58xx series closed box wagon.
Kind regards,
Henrik
