Hi to all my fellow enthusiasts.
The long awaited V7 version is now available so for those interested in the upgrade here is a link that will get you started. https://community.3d-modellbahn.de/wiki/allgemein/%C3%BCbersicht-%C3%BCber-die-neuen-funktionen-v7-r33/
Enjoy. I'm sure I will, from a brief glance there are some amazing treats in store. I only hope those with larger layouts such as mine have been accommodated. Only time will tell as I work through all of the goodies.
Pete
Hi Pete,
V7 is here, but please note that we are currently in beta/testing phase, which means that everybody can already use the new version, but some points are still left (especially updating the wiki, some small fixes).
See here for more information.
Kind regards,
Hi Neo
Knuckles duly wrapped if I have jumped the gun but after only a very brief glace through V7 I have to say that it seems to have surpassed all expectations. Great improvement on V6, brilliant. I'm sure there are many like me who will put up with the fixes to follow element just to be able to explore the new version.
Kind regards
Pete
  • 3 Wochen später...
Hi,
yes, all upgrades are backwards compatible, there are only small adjustments needed when upgrading, see here. In addition, you can always test the new version without affecting you existing layouts, V7 uses a different database folder than the other versions as default.
Kind regards,
On 9/14/2021 at 10:33 AM, Neo said:
V7 is here, but .. we are currently in beta/testing phase,
it looks like a really busy beta/testing phase - yesterday I downloaded, installed
and run the new v7 (v7.0.4.0), and it promptly announced "update available" :)
Bearbeitet von hajo4
Hallo @Neo
ist es vielleicht möglich mehrere mbe Dateien in einem Rutsch in den Katalog einzufügen?
Der Grund ist, das ich mir viele MSTS Modelle erst in V5 eingefügt habe,
die Modelle die für V5 zu viele Polygone haben in V6
Gruß Hermann
Okay, so, two questions:
1) The functioning of deceleration track contacts seems to be intermittent.  In the one layout I've so-far published, the contacts to stop the train at the station work sometimes and not others.
Here's the event, and the contact setting:
Going one way, the train overruns the station sometimes, while going the other it sometimes fails to stop at all, or slows then speeds up again.
2) Are there any other differences between "real" and "Model" than the one's I've spotted?
  • The initial baseboard is bigger and pre-painted with grass in "Real"
  • All scales of track come out the same size in "real".
Also on that note, is it still possible to create narrow gauge railways? It's been a while since I actually looked but there used to be a gauge called Double-Oh Nine (OO-9) that was the same scale as OO but the track was N-gauge.
Bearbeitet von simonjackson1964
typos
Well, since I posted that, and have made no changes whatever, it now seems to be working fine...
Which is always the way with intermittent faults. The number of times I've reported a problem to the IT department at work and they've come back with "Unable to locate the problem..." Oh well.
If it happens again I'll try and capture a video.
Hello Simon,
vor 49 Minuten schrieb simonjackson1964:
when your train has more than one engine
and
the engines have different deceletration settings
... it will overrun the stopp marker.
Also please note: the brake force must be sufficient.
e.g. for a train running at 80 km/h, the deceleration must be set to a minimum of 2 m/s²
for higher speeds, higher deceleration settings are required
Greets
Goetz
vor 35 Minuten schrieb simonjackson1964:
Well, yes. It worked in V6... and it seems to have stopped doing it now.
But I have another question: playing with V7, how do you create a "virtual depot"?
Hello @simonjackson1964,
It's very simple. All you need is explainded here in the wiki in the chapter  "Virtuelle Depots und virtuelle Verbindungen/Portale".
Best regards. Michel
17 minutes ago, michellombart said:
Hello simonjackson1964,
Nice, thanks.
But.... Where are they in the catalogue?
Never mind, found them!
DFound what I was looking for!
