Dad3353 Geschrieben 13. April 2024 Geschrieben 13. April 2024 Good evening... I have an animation (treated as a vehicle by MBS...) which would be best at the original speed, to be more realistic. Here's a video, with the 'vehicle' speed set to its minimum of 1 km/h. Can this be reduced to 0.5 Km/h, by code, for instance..? Thanks in advance for thoughts... Guten Abend... Ich habe eine Animation (von MBS als Fahrzeug behandelt ...), die am besten mit der Originalgeschwindigkeit funktioniert, um realistischer zu sein. Hier ist ein Video, in dem die Fahrzeuggeschwindigkeit auf mindestens 1 km/h eingestellt ist. Kann dies z. B. per Code auf 0,5 km/h reduziert werden? Vielen Dank im Voraus für Gedanken ... Douglas
Goetz Geschrieben 13. April 2024 Geschrieben 13. April 2024 (bearbeitet) Good evening Douglas vor 51 Minuten schrieb Dad3353: I have an animation a wonderful animation! You can use the "set vehicle speed" command from the "vehicle" section of actions in the EV to assign low speeds like 0.5 or 0.2 Please note that my Windows Settings are German. This includes the comma as the separator for fractions. You may want to use the period instead. When I tried the period, my number turned red. Yours will probaly turn red when you use the comma (like I did in this screenshot). Greets Goetz Bearbeitet 13. April 2024 von Goetz additional explanations
Dad3353 Geschrieben 13. April 2024 Autor Geschrieben 13. April 2024 1 hour ago, Goetz said: Good evening Douglas a wonderful animation! You can use the "set vehicle speed" command from the "vehicle" section of actions in the EV to assign low speeds like 0.5 or 0.2 Please note that my Windows Settings are German. This includes the comma as the separator for fractions. You may want to use the period instead. When I tried the period, my number turned red. Yours will probaly turn red when you use the comma (like I did in this screenshot). Greets Goetz Many thanks for the swift response, and a welcome solution (admittedly to a very minor problem, but still...). Here in France I'm quite used to using a decimal comma; it shouldn't be an issue for me. Thanks again, old chum. Douglas
Klartexter Geschrieben 13. April 2024 Geschrieben 13. April 2024 Hallo @Dad3353, gibt es in England noch keine Rollatoren? Die Gehhilfe in Deinem Video kenne ich eigentlich nur aus dem Krankenhaus. Der Link führt zu einem Bild, auf dem man sieht, was ich meine. Aber Du hast die Animation sehr gut hingebracht! Hello @Dad3353, are there no rollators in England yet? I only know the walking aid in your video from the hospital. The link leads to a picture where you can see what I mean. But you did a great job with the animation! Walter
Goetz Geschrieben 13. April 2024 Geschrieben 13. April 2024 vor 53 Minuten schrieb Klartexter: gibt es in England noch keine Rollatoren? Oh Mann, Klartexter. Die Bewegungen mit diesem Gehrahmen sehen einfach viel interessanter aus. Und man sieht die (wenngleich seltener) auch im Alltag. In früheren Epochen (bei Modellbahnern sehr beliebt) sah man sie noch häufiger.
Dad3353 Geschrieben 13. April 2024 Autor Geschrieben 13. April 2024 1 hour ago, Klartexter said: Hallo Dad3353, gibt es in England noch keine Rollatoren? Die Gehhilfe in Deinem Video kenne ich eigentlich nur aus dem Krankenhaus. Der Link führt zu einem Bild, auf dem man sieht, was ich meine. Aber Du hast die Animation sehr gut hingebracht! Hello Dad3353, are there no rollators in England yet? I only know the walking aid in your video from the hospital. The link leads to a picture where you can see what I mean. But you did a great job with the animation! Walter
BahnLand Geschrieben 14. April 2024 Geschrieben 14. April 2024 Hallo / hello Douglas, schimpft die Dame so, weil sie aus ihrem Gefährt nicht mehr Geschwindigkeit herausholen kann? Is the lady grumbling because she can't get more speed out of her vehicle? Viele Grüße / many greetings BahnLand
Dad3353 Geschrieben 14. April 2024 Autor Geschrieben 14. April 2024 (bearbeitet) She's heading for an unprotected level crossing, but has forgotten how to brake. Sie ist auf dem Weg zu einem ungesicherten Bahnübergang, hat aber vergessen, wie man bremst. Bearbeitet 14. April 2024 von Dad3353
220hotwheels Geschrieben 14. April 2024 Geschrieben 14. April 2024 43 minutes ago, Dad3353 said: She's heading for an unprotected level crossing, but has forgotten how to brake. Sie ist auf dem Weg zu einem ungesicherten Bahnübergang, hat aber vergessen, wie man bremst. Hi Douglas Have you added a squish sound to the sound track? Cheers Pete
