Alle erstellten Inhalte von Leslie
Maximum speed
Sometimes I need maximize speed to zero. I need prevent manual towing and engine off is not always solution (it cancels particle effect also).
Aktion "Blinken"
If this function is exists also need adjust its speed.
Weichen: wechseln zwischen virtuell und spline geht eine Spur verloren
If there is only 1 segment in all lines then MBS automatically recalculate road. I think this is the problem here. Solution: you must use 2 spline or at least 1 pc. of 2 segment line.
How to fasten vehicle in place?
Engine off is not solution here, max speed can not set to zero and link must not removed. Parking brake also does not work. I wish to prevent manual towing in simulation mode.
Turnout problens
If any turnout is locked then can not program its actions. No error message but it works wrong way.
Scenic railway
Slightly adjust - plus a test feature: if train suddenly starts while editing that because telephone animation is accidentally stopped. I can not catch cause so I have written this test. scenicrw.mbp
Irgendwo in Deutschland
It is beautiful. Only one thing is not in place... please replace all turnouts with model-oriented version and set to W04. This will perfect view for turnouts.
Visible metal ball
I wish to use a shiny metal ball in MBS. Primitives are not good here or I can not found method. Is there a solution?
Karls Modellbau
These are 0-level models better than nothing. I also think strings are required and not too much to program.
4 Rotoren
This is only for decorations, unable to move. Circles are not linked, any move destroys this drone. And 70 objects for a single vehicle? Otherwise it is a very good-looking model.
- Airport
EASY's kleiner Modellbau
I think in this case a continuous animation may be better.
Traffic park of Csepel - draft
Drivers fully obey both traffic lighs and policeman. No pushing anymore in these scenes.traffic.mbp
Vehicle follow problem
This is not solution. The traffic signal must change and car which in range must stop. This found yourself in disabled place when can not move. But it is not reason for next to drive into.
As seen in the picture if a car stops partly in disabled route then next car does not recognise it and drive into. I have checked they are in the same route. It does not occors if both are in enabled routes. The last car in hard mode so physical contact possible. Please see this case and tell me what to do. Currently bicycle does not count, this is in different route.
Arabic fantasy
Slightly adjusted. Normal turnouts, crossings and not a floating rail anymore. Arab.mbp
Event "An Animation of Object is Started/Stopped" selection
There is a condition in events: It is not ideal but usable. 2 separated events maybe better. Also the cranes same problem and solution.
Turnout problem
There is a normal turnout not programmed so all lines are enabled by default. If I disable some lines with "disable track route" command than vehicles programmed "burst open turnouts" cannot drive in. Is this normal?
My first "faller" layout
I created a new case model like 1. The bottleneck here is the middle... and direct of turnouts. This is what I created first: This is great but unplayable. These cars are racing side by side. So I created this:faller3.mbp This works correctly.
Neue Foren-Softwareversion
I see new forum, it seems good-looking. I think it is connected to MBS, so I suggest to display base picture of sample layouts in forum by default. Thank you in advance.
Scenic railway
Railway maybe too dark. This is lighter plus some adjustment: scenicrw.mbp
Scenic railway
Ghost railway is not full without a profi ghost so I hired an authentical one. I know parents are also ghosts.scenicrw.mbp
Scenic railway
91A3643D-9B76-4A4A-9058-051A0247A90D is a serious work with 2800 objects. I am very far from this yet especially terrain. Thank you to show me this!
Scenic railway
It was one of the best thing in the amusement park. It is closed now, so I created a memory. I am in the lack of poor models so I plan expansion.scenicrw.mbp Not recommended for children under age 9.
Visible layers
Which LUA commands to handle this?
