hubert.visschedijk
    1785
Alle erstellten Inhalte von hubert.visschedijk
  1. Nobody can compete with the thoroughness of @BahnLand´s explanations Niemand kann mit der Gründlichkeit der Erklärungen von @Bahnlands mithalten
  2. New inbox !
  3. You not leave the textures files zipped before importing the model into MBS. (might be the other reason why textures are not going along.) So , before importing into MBS, the archive contents are: The x-file and the textures as they are "power of 2".
  4. You have to do this before importing the materials. I have never tried, but this might be the problem why textures are not going along with exporting it. And to keep within the texture and material limits, especially when you are going to add transparent textures, animations, or even _CP points, that you use one texture only. So, gather all in one. 256x1024 or 512x 1024 or 512 x 2028...whatever.
  5. Dad, save the design as SKP 8 and send it to me ? I just send a PM with my email adresss. A reminder, MBS accepts 5 textures max. I
  6. @fmkberlin bevor ich alle spuren ausprobieren muss .... Weißt du, welchen spur ich verwenden soll, der die richtigen weiche für diesen spurabstand hat?
  7. @Dad3353 Dad, nevertheless which version you download... (2017 is better offcourse) The signup for sketchucation is still good, to download all the plugins you need and want. And help enough around here to get you on your way !
  8. Bahnland... vielleicht solle ich nach 17 gehen. Hast du den EXE. fur mich ? Bearbeitet... hab schon der link oben geoffnet... Vielen dank !
  9. @BahnLandwas quicker hahahaha
  10. Download the DEA or KMZ files. KMZ is better, comes with the textures incluided. Excellent videos aswell on youtube, from beginners to advance. Ideal also to write in to sketchucation to download some plugins. If you want, i can send you the ones i have installed that are the real important and basic ones that you wil need. fredo tools collection, center on origin, bizarspline curves, rotated tri-angle, Clean UP 3, and some others Glass in SKP; Besides the texture you have created and imported, you can create one transparent texture with in SKP that will be accepted by MBS. Cant say how much it is with blender. For glass i use normal regular grey and set the transparency on 50% Animation is another subject... but can get to that aswell. @BahnLand is master in that and i am (still) his pupil allthough i getting around quite well...
  11. @fmkberlin Ein weiteres fantastisches Modell! Nur eine Frage; Was ist die beabsichtigte Spurentfernung auf der Brücke selbst? Da ich es gewohnt bin, immer N-Spur mit 33,6 Spurabstand zu nehmen, habe ich bereits gesehen, dass dies nicht über die Brücke selbst passt. Treffen hier offizielle Entfernungen zu oder rücken Gleise an einer Brücke immer näher zusammen? Ich versuche das zu verstehen , weil es mehr Brücken gibt, bei denen man mit 33.6 nicht überqueren kann, ohne die Spuren näher zusammenzubringen. Wie Ihre Bögenbrücke und die variable Brücke von Roterbrummer. Also, was ist der Standard, denn dann werde ich mich darauf einstellen.
  12. Bitte apfelstrüdell mit richtige sahne und blutorangensaft...
  13. What version would you like ? i still got the old 8 version. Does everything i need. I have the PRO20 on my pc, but thats the smiley with one eye-lap version.... So not using...
  14. Yes, you can ! But ill stick to SKP...
  15. skispringer konnte doch schone animation geben.. bobfahrer auch.... und mit V6 werde die kurven einfach sein, nicht ? (hum...nein)
  16. Tec, Es ist ein schönes Modell die Ich habe jedoch Probleme bei der Installation der oberleitung. Glaubst du, es wird ein Update geben, um das Dach anzuheben? Mein Vorschlag wäre; Wenn die Plattform in Ihrem Zeichenprogramm vom Dach getrennt ist, können Sie die Dachbeine leicht nach unten ziehen und dann das gesamte Dach anheben. Denn das Anheben der Plattform bedeutet auch, dass Sie die Station usw. einstellen müssen. Das kann zu viel Arbeit sein. Viele Grüße, alles ist gut gemeint.
  17. markus.... Aldi 02BD7C07-E351-4E6C-B425-CA4E3A9FEC7F Aldi2 600BD571-815C-4075-8629-6B5B7B5E7FB9 Und so gibt es auch Edeka (3), Lidl, Kaufhaus, Obi, usw Such mal unter Infrastrutur>Stadt und land>ladengeschäfte Und mit ein wenig Fantasie können Sie auch Ihre eigenen machen! Viele grusse
  18. Hallo alle Das Standseilwagen wurde offiziell hochgeladen, damit es nach @Neo Einschätzung zusammen mit den besonderen Spuren von @BahnLand im Katolog zur Verfügung gestellt werden kann. Ich habe auch Rauheitstexturen zur Straßengalerie und zum Trestle Brücke fahrspur hinzugefügt. Diese warten daher auch auf ihre Veröffentlichung.Ein alternatives Modell wurde ebenfalls hinzugefügt, damit es auch in der Stadt verwendet werden kann. Das Seehaus (oder Strandhaus) wird ebenfalls offiziell hochgeladen. Ich habe auch geholfen, @manfredkropp Marklin-Brücken zu aktualisieren, und ich hoffe, er hat sie bereits hochgeladen, damit Sie sie genießen können (noch mehr). Mit vielen Grüßen,
  19. Achtung Achtung ... Max 'Liste ist geschlossen ... bis 2023 wird er beschäftigt sein!
  20. Max, wie lange ist die liste jetzt ?
  21. Aktualisiert ! C605E468-B7C5-42E6-BC92-624CD7104AF2
  22. Daran hatte ich nicht gedacht. Also werde ich das ändern. Danke für den Tipp !
  23. Ja Trotz der Tatsache, dass dies im wirklichen Leben nicht der Fall ist, würde das Modell in MBS sehr außerhalb der weiche laufen ... Viele grusse
  24. und für wen es interessiert; Hier eine Website mit (glaube ich) allen Standseilbahnen der Welt. Mit Fotos und Videos. Schließlich wird viel geforscht, um ein neues Modell zu bauen ... http://www.funimag.com/photoblog/index.php/categorie/germany/
