2304 -
Beiträge erstellt von maxwei
Hallo Vermanus
In der WIKI steht schon sehr viel, solltest du explizite Probleme lösen wollen dann wäre es wohl am Besten diese hier im Forum anzusprechen.
lg max -
I hope this gives you alittle more information.
I dont want to write an exactly step by step procedure, 'cause if you learn with this its easier to remember the next time, but if you want this, I can do that .
vor 13 Minuten schrieb Dad3353:How, then, did you 'bind' the _CP_Target to the wheel, before baking, please..?
Almost Correct, not to the _wheel but to the Test_point (which is a child of the _wheel) and after "baking" the "Constraint" is not longer activatet, 'cause we made a keyframe-animation out of a calculated animation
lg max
hi DAD
I have tinkered times on the quick what you might help.
The trick is (maybe there is another possibility) to animate the_CP_Target via a constraint.
In this case the "Child" constraint, where you still have to define the directions and then press "Set Inverse".
The whole thing needs an auxiliary child (in the example below the hexagon) which is then linked to the horse).If the animation works in Blender you have to "bake" the _Empty-Animation
lg max
You want the rider to be linked to the horse?
Sorry, my mistake, then of course you need the rider as _CP_Source and the horse as _CP_Target, cause they belong together and when the horse moves it takes the rider with it.
You make these points in Blender with an "Empty".
Hi DAD
You do not need to name the ContactPoint _CP_Source ('cause this is a special Contact Point and needs mandatory a _CP_Target).
You just have to name the rider e.g _CP_Rider (or _CP_whateveryouwant), and the saddle _CP_Saddle (or _CP_whateveryouwant):
Whenever there are 2 _CP's ("the normalones") , they can find each other when close enough.
lg max
PS: reserved expressions for special purposes:
_CP_Source
_CP_Target
_CP_Spline
_CP_Track
_CP_Track_Dynamic -
ich habe mal ein bisschen gegoogelt in Bezug auf Copyright von z.B. Texturen, Fotos, Hintergründe für Modelle oder Anlagen.
Wer sich etwas damit auseinandersetzen möchte dem empfehle ich folgende WIKIPEDIA Seite, in der genau beschrieben die CC's (Creative Commons) sind, eine Organisation für Standard-Lizenzverträge, welche in derzeit unterschiedlichen Formen auch in D,A, und CH, gültig sind.
Creative Commons Wikipedialg max
Hallo Reinhard
Wenn es dir möglich ist dann auch von mir "Alles Gute, und immer schön auf die Krankenschwester hören".
lg max
vor 2 Stunden schrieb Hawkeye:
Windows 10 wird aber, wie ich gelesen habe, noch bis Oktober 2025 mit Updates versorgt, also hat das ganze (für mich) erstmal keine Eile.
Erstmal die Resonanz abwarten.
Das ist auch meine Devise, erstmal die ersten vielen Patches abwarten und dann vielleicht nächstes Jahr, wenn überhaupt , umsteigen.
lg max
Ich hab's mal aufgeschrieben
lg max
Hallo Hans
vor 10 Stunden schrieb h.w.stein-info:Kann versuchen vor Ort in Köln einer der Mitarbeiter zu fragen , ob die es Wissen können .
Brauchst dir nicht die Mühe machen, das ist es nicht wert, ich lasse es so wie es ist, kommt zumindest auf den Bildern halbwegs korrekt rüber.
lg max
Hallo zusammen
Vielen Dank für die Likes und Kommentare.
vor 7 Minuten schrieb h.w.stein-info:Du kennst dein Modell besser als Ich .
Wäre ja befremdend wenn's nicht so ist.
Zwischenfrage zur Optimierung nachdem ich im Netz nichts darüber gefunden hatte. Weiß jemand die RAL Nummer dieses Grün's?
lg max
ich kann's mir einfach nicht verkneifen, aber jetzt, nach 2 Monaten, das Modell schon längst wieder aus der Datenbank entfernt, keinerlei Antwort von Appenzeller, habe ich das Gefühl, das ich wohl doch nicht so ganz unrecht hatte zu Beginn (übrigens war Appenzeller's letzter Besuch am 1. August),....das musste ich jetzt loswerden.
lg max
Hallo Hans, kann ich machen (stelle hier die 3 Varianten als Bilder ein, damit ich mir eine Vorstellung machen kann)
lg max
PS: OK, Nachdem ich auch noch von anderer Seite angesprochen wurde zwecks weiterer Variation mache ich hier noch einen Aufruf:
Wenn ihr mir Bilder schickt von gewünschten Variationen (diese müssen nicht sehr groß sein, nur damit ich weiß was es werden soll, dementsprechende Vorlagen suche ich mir dann selbst) werde ich versuchen alle Wünsche zu erfüllen sofern es die Textur zulässt.
lg max
Hallo NEO
Ich kann von hier keine Bilder verschicken, aber metallic ist hellgrau und roughness ist dunkelgrau (nicht ganz am Anschlag), nur an den Wänden und Front, nicht das Dach, wenn ich jedoch beide auf Anschlag gebe, dann kommt wieder das zu extreme grün/graue (nicht schöne) als Reflektion hervor. Vor allem bei den dunkleren Farben, das Einzige das ich machen könnte, wenn auch mit viel Aufwand verbunden, jeder Lackierung einen individuellen M/R zuzuweisen.lg max
Hallo zusammen, nach einem Abstecher zu einem anderen Thema welches vorerst auf Eis gelegt wurde hab ich mich der Erneuerung der Vectron gewidmet.
Fehler wurden korrigiert, Materialsystem auf PBR umgestellt, Emissive statt _LS erstellt, Führerstand upgedatet, LOD's überarbeitet und die gesamte Flotte komplett hochgeladen mit der Bitte an @Neoum Freigabe.
lg max
Sorry Tec, wenn du das meinst mit den Komparsen finde ich es äußerst geschmacklos.
max
Hallo Hajo, zusätzlich zu @Goetz' Ausführungen...
vor 13 Stunden schrieb hajo4:Objektanzahl ?
bekommst du mit einem Doppelklick auf die FPS-Rate ganz rechts unten.
lg max
Wunsch nach nem aufgeklappten Koffer
in Modellwünsche
Ich wollte dir nur zeigen dass man das ganz leicht selbst machen kann
lg max
