Hier bitte eure Anmerkungen zum Thema "Bau von Modulen" posten.
Danke
Suggestion for a few more panels...
First an L-Form
Dimensions as shown below.   this gives us 300mm on each end.
this can be used for corners.
Second, a T-Form for center Isles.
the T-Form is 2 panels, one is 1000 x 300, and the second is 300 x 300.   Offset is necessary with top being offset 150 and bottom being offset -150 so that center, where the two pieces meet is at 0,0
Hello Curt,
thank you for your comment.
The construction of curve modules will be described as soon as the basic shape is sufficiently explained.
For the T-shape it still has to be clarified what happens to the background scenery. Where will it be placed? Is there even one?
Greetings
Hallo Curt,
vielen Dank für deinen Kommentar.
Der Bau von Kurvenmodulen wird beschrieben, sobald die Grundform ausreichend erklärt ist.
Bei der T-Form muss noch geklärt werden, was mit der Hintergrundkulisse geschieht. Wo wird diese angebracht? Gibt es überhaupt eine?
Warum nicht auch vorne Module ohne Hintergrund anbauen?
300 ist nicht viel.
background scenery would be placed along the long side as shownT.thumb.jpg.e5816055ff4d84483cfc6e3947d120d9.jpg
To Clarify,  when you are laying track for this module,  you are using single track, and the track is centered at 0,0 (X,Y)?
Exactly:D
so, in theory you could create a siding off of the main line that runs nearly the length of the module, or create 2 modules that go together with a long siding, and even create a yard as long as the main line was all that remained at the ends of the module.
Hello Curt,
vor 5 Minuten schrieb Curt84328:
in the catalogue there are already some modules of mine, where exactly this is practiced.
10EEF2A5-A238-46CF-9E89-D1E7D7FF61C6
818D1221-9818-4F93-BAC5-5AB58E3548C3
8987D504-18F4-4D6C-A385-A858666BF79D
DD3682EB-61AB-4CC3-BDBE-CC71D774A329
Greetings
Hallo RB
Wie sieht denn Dein Bahndamm bei 90 Grad Kurven aus inkl. der Schottertextur?
Guckst du hier:
88D18A2B-A4DD-4668-82AC-B2D2DE3A07A6
oder hier:
Bearbeitet von Roter Brummer
ich habe wieder ein wenig gebastelt und das Modul mit dem Bahnübergang von Brummi etwas modifiziert, so dass man jetzt rechts das Campingplatzmodul ansetzen kann. Für die andere Seite überlege ich mir auch noch etwas.
Gruß Ronald
Bearbeitet von randermann.tbb
Ergänzung Text
Hallo Ronald,
prima! Genau so geht das nämlich. Es gibt so viele Ideen mit diesem System, die kann einer alleine gar nicht haben.
Zum Weiterbau nach rechts gibt es meiner Meinung nach zwei Möglichkeiten. Entweder baust du noch ein Modul, wo die Strecke wieder zurück in die Mitte des Modulkastens führt. Dann kann jeder andere User sich mit seinen Modulen dort andocken. Oder wir definieren gemeinsam einen genormten Versatz der Gleise nach vorne oder hinten. Dann gäbe es vorgefertigte Module, die zum Versatz führen, ihn fortführen und wieder zurückkehren.
vielen Dank für die Likes. Hier mal das Basismodul mit aussen liegendem Gleis:
Das Gleis liegt bei y= -107 immer vorrausgesetzt, dass die Bodenplatte bei x,y=0 liegt.
Eine eventuelle Straße oder Feldweg liegt bei y= 87
Gruß Ronald
Hallo @Roter Brummer,
ist die "Anleitung zum Bau von Modulen" von deiner Seite her abgeschlossen, oder gibt es noch weitere Teile?
Siejay
Hallo @Siejay,
da kommt noch was. Ich arbeite daran. Manchmal müssen Ideen ja auch etwas reifen und zum Glück ist das für mich kein Beruf hier, so dass eine "schöpferische Pause" erlaubt ist.
eigentlich hatte nur gefragt ob das Thema weitergeht oder abgeschlossen ist, und keineswegs gedrängelt oder gefordert.
Siejay
vor 1 Stunde schrieb Siejay:
hab ich auch nicht so verstanden.
  • 1 Monat später...
Hallo liebe Leute,
ich habe mal wieder ein kleines Modul gebastelt, mit dem herrlichen kleinen Güterschuppen von @Roter Brummer, aber seht selbst.
Gruß aus Bremen
Ronald
MiniMaxRR05.mbp
Hallo Ronald,
ich würde mir wünschen, dass dieses Modul in den Modul-Pool aufgenommen würde.
Hallo Brummi,
gerne kannst du das Modul in den Katalog hochladen. Vielleicht muss ja auch das eine oder andere angepasst werden.
Gruß Ronald
P.S. vielen Dank für die Likes.
Ergänzung
  • 3 Jahre später...
Am 14.3.2020 um 22:02 schrieb Roter Brummer:
Ich auch - aber das kannst ja nur Du machen.
Beste Grüße
Phrontistes
