1173 -
Hello @EASY , great models, I'm looking at them here in a layout. ( the drafts ) But I cannot put the lights on. ( no properties available ? ) Kind regards, Herman
Laternensteuerung mehrerer 3-Wege-Weichen
Herman antwortete auf anschnipps Thema in Fragen zur Steuerung
Hello @anschnipp , I found this in the catalog. Maybe there is something in for you, I'm not sure ? "Dreiwegeweiche mit Signal" von Easydiver. D2C3A7B6-F6F4-4E93-9DC0-34A35873C3DC. In online catalog, modules to insert. Kind regards, Herman -
Hello everybody. This is an old game, or more a riddle ? Two players compete on a chess board with only a chess queen, he/she who first reaches the tile on the bottom right wins. I found Jeannie ( model from @Jim Knopf ) and let her play against you on a big chess board. You must start, and it is even possible to win. Can you solve this problem ? Have fun Kind regards Herman. Because not train related, only a draft : A383864E-A288-44FF-A35F-02E721956650
Hello, since @EASY helped us with the function quaternion_to_euler(x, y, z, w) , the problem is solved ( for me ). I only wanted to find the x° y° z° global angles of an object in Lua. Thank you Easy ! Kind regards , Herman
Hello @EASY , for such a nice solution thank you very much. I'm very happy with that. Kind regards, Herman
Hello @Hawkeye . The 45° in my picture is the angle in the global system. ( we see it at positioning ). It is seen after your rotation of -15°. It started at 60°. Ok you wanted that, and did not achieve that; I did not know it. But I'm only interested in the angles vs the global system. So it did correct the -15° rotation in the global system. And I cannot find in Lua the 60° or the 45° for a specific object in the global system. But will we please leave it now ... Kind regards, Herman
Thank you @Goetz so I did understand that. Now the remarks on @Hawkeye 's example print("globale Objekt-Rotation:") print("Rotation(rad) um x =",FZahl(Rotation.x,2), "y =", FZahl(Rotation.y,2), "z =", FZahl(Rotation.z,2), "w =", FZahl(Rotation.w,2)) print("Rotation(Grad)um x =",FZahl(math.deg(Rotation.x),2), "y =", FZahl(math.deg(Rotation.y),2), "z =", FZahl(math.deg(Rotation.z),2), "w =", FZahl(math.deg(Rotation.w),2)) I do not agree with this formulas. You only take the x, y, z, w from the Quaternion. Conversing to radials or degrees is a lot more complicated. But why not some pictures , what I mean is : start rotate with your program over x 15° The pictures are correct, your example does the job, but : So I still cannot find in Lua ( see the prints ) the wanted angle before or after the rotation. Hawkeye, but I appreciate it a lot you wanted to give some help. Let us leave it for now at "feature request". Kind regards, Herman
Hello @Hawkeye , thanks for your example. It is the global angle that I need, not the local. A question : when we change from global to local or vice versa, only the view of the axises changes. ( to move stable along an axis if wanted ), but the values we see in positioning for the angles are only the global one. ( correct ? ) I have remarks on your example, but it takes a while to explain this correct. I learned already a lot out of your example, so thank you. See you again here. Kind regards, Herman
Hello, @Hawkeye , thanks for the support. I'll have a look at your example. No sorry at all. We all can use Google translate here. Recent I too only work in one language here, however English. My German is not good enough. Yes, I already said that is probably so, that's why I went to "feature request". Hello, @Goetz , thanks for the reaction at @simonjackson1964 , yes I know. And I'm not looking to some formulas to find it, only if it should be easy available. Since Neo uses the quaternion to rotate, and shows the values in positioning, maybe ... ? But I repeat, an exotic request, and maybe the users will never want to use it. Kind regards, and thanks again. After looking at Hawkeye's example more toroughly , maybe I'll come back here. Herman
Hello @Neo , just a request for the future. Not an important one because we do not use it often directly, and exotic, only a few members will use it at all. So only a wish. In his studio Neo uses frequent rotations to perform wanted operations of the user. So Neo has already the necessarly tools to do some of the wanted calculations. This two are already given free : local t = $("an object").transformation.rotation -->but not very user friendly because of the quaternion. and $("an object").transformation:rotateZ(math.rad(30)) --> works fine, rotates further over 30° ( z -axis ) But if we want to find the angle an object is already rotated at the moment, or if we want to rotate directly to a specific rotation ( without knowing the actual rotation ), it is not given free. So I'm thinking of something like the following. Let us start with 0,0,z' (*) local a = $("an object").transformation.rotationZA --> where the result is the actual rotation angle over the z axis in rad. ( here the result is z' ) and of course also $("an object").transformation:rotateZA(math.rad(30)) --> where the object will end on the actual rotation of 30° ( z-axis ) ( here it should be ok if we only could rotate directly to 0,0,0 , already possible workaround -> rotate equal to an object at 0,0,0) As I said, only a wish, only should it be possible without much work for Neo. Kind regards, Herman ( * due to rounding errors, not all rotations over x,y,z are possible in the studio, so my question is specific when an object has two of the 3 angles = 0 , in my case 0,0,z' as said before ) If we fill this angle in, Neo will immediatly rotate to the 55,58 ° as wished. So he has this tool somewhere ?
Hello, since ( I think ) there is not an easy solution for my question (for now), and I'm not looking for some formulas, see further under "feature request". Kind regards, Herman
Hello, thanks, but this value is not the angle ( z ) in radians of that object. ( convert with math.deg print and see ). The second one : $("BR 80").transformation:rotateZ(0.25) is known by me and does correct the job for that angle in rad. ( I sometimes use it , to rotate further over x rad) Kind regards , Herman
Hello @prince , is there something wrong with the ID nrs ? Greetings, Herman
Hello, I need some help. How can I get the value of the rotation (over z) of an object ? ( Lua is fine, angle or rad is ok ) And then on some conditions, rotate it to another angle. (over z) Thanks in advance. Kind regards, Herman
Hello @Andy, even I knew that. That's not wat I ment. In real live the tower is somewhere connected to the church, it is not an other separate building. But for me the model is fine as it is. Not important. Greetings, Herman
Hello @EASY , splendid model ! I noticed that the tower was not connected to the church. I mean the small opening between the tower and the church. Maybe wanted, and not a problem. Just saying Greetings, Herman
Hello to all, thanks to the tip from @Phrontistes , the GBS panel is now protected against changing the signals and/or track switches directly. Same ID nr. Altough this is possible, I did prefer not to do the same in the layout. The warning stays, do not change signals and or track/switches directly in the layout. In the Gbs panel it was really needed, a wrong 2x click in the In the surroundings of the buttons can happen easily. Have fun, thanks for looking. Herman
Hello @Phrontistes , thank you for the tip. Kind regards, Herman
Hello everybody. No, just a joke, when I saw my ugly gbs control panel … a title was found. In this layout you can swith automatic on / off. When off you have some limited influence on where the trains are going. But even then the routes control the safety of the rolling stock. With the use of reserved tracks ( yellow ) or occupied tracks ( red ) you can handle the rolling stock. Do not use the signals and/or track switches directly on the gbs panel. It is not conform with the built in routes. Thanks for looking, have fun ! Kind regards, Herman. D57E7A2A-1F2A-4A80-A716-571FE168F22D V8
Hello @ronny_the boos_ schindler , An important remark : when making routes with a turntable involved, always set the turntable in the correct position for that route, or you cannot make it. Hallo @ronny_the boos_schindler , eine wichtige Anmerkung: Wenn Sie Routen mit einer Drehscheibe erstellen, stellen Sie die Drehscheibe immer in die richtige Position für diese Route, sonst können Sie sie nicht erstellen. Kind regards, Herman
Hello @ronny_the boos_ schindler , Because your question was specific, I tried to make a starters demo about a turntable, and what you wanted. V7 To make the routes you have only to select the start ( a signal ) and the end ( a signal or a track contact ), and accept. Good luck, and give some feedback if it helps. Da Ihre Frage spezifisch war, habe ich versucht, eine Einsteigerdemo über einen Drehscheibe und Ihre Wünsche zu erstellen. V7 Um die Fahrstraßen erstellen, müssen Sie lediglich den Anfang (ein Signal) und das Ende (ein Signal oder einen Gleiskontakt) auswählen und akzeptieren. Viel Glück und gib uns Feedback, wenn es hilft. Regards, Herman Turntable demo.mbp
Bremskontakt ändert selbstständig seine Eigenschaft
Herman antwortete auf George 63s Thema in Fragen zur Steuerung
Hello @Neo , thank you for this usefull information. Hallo @Neo , vielen Dank für diese nützlichen Informationen. Kind regards, Herman -
Hello @ronny_the boos_ schindler , if you have V7 or higher, it can easily be done with routes, if you want to use routes. For specific help, see the note of Phrontistes. Hallo @ronny_the boos_schindler , wenn du V7 oder höher hast, kannst du das ganz einfach mit Farhstraßen machen, wenn du Farhstraßen verwenden möchtest. Für konkrete Hilfe siehe die Notiz von Phrontistes. For what it is, I once made this one. Für das, was es ist, habe ich dieses einmal gemacht. 65263180-0070-4304-9936-B8F5A05A33DC (V7) Kind regards, Herman
Sorry if I am mistaken, but there are a lot of new models released in V8. Not the last day but if we talk about some weeks. And very nice models. Tut mir leid, wenn ich mich irre, aber es werden viele neue Modelle in V8 veröffentlicht. Nicht der letzte Tag, aber wenn wir über einige Wochen sprechen. Und sehr schöne Modelle. Nice regards, Herman
Connection between TC and GBS (V8)
Herman antwortete auf Hermans Thema in [International] Problems and solutions
Hello @Goetz , nice explanation thank you that explains it. We can set it individualy according the direction of the TC. ( 0 off , 1 yellow, 2 red ) Hallo @Goetz , nette Erklärung, danke, dann wird es erklärt. (Wir können es individuell entsprechend der Richtung des TC einstellen. ( 0 aus, 1 gelb , 2 röt ) I should have known this, a simular discussion ( the setting of a signal in general, not a gbs ) was there a time ago. Forgot it. Ich hätte das wissen müssen, eine ähnliche Diskussion (die Einstellung eines Signals im Allgemeinen, nicht eines GBS) gab es vor einiger Zeit. Hab's vergessen. But it helps, thank you very much ! Kind regards, Herman
