Bonjour @arnyto,
1. installer MSTS.
2. Installez Shape Converter.
3. installez Shape Viewer.
4. convertissez le fichier s du modèle en fichier 3ds avec Shape Converter.
5) Convertir les textures d'as avec Shape Viewer.
6. éditer le modèle 3d et assigner les textures, j'utilise Metaseqoia 4, sauvegarder en gltf.
7. insérer dans MBS
162931764_BR110150MSTS-V6.thumb.jpg.5705c115e2950ccdcdac0c7004ddb9c2.jpg392758960_BR110188MSTS-V6.thumb.jpg.1fac98bca05b7cb2a4f7f2e132aa98df.jpg1124640830_BR110215MSTS-V6.thumb.jpg.0b2802199d9f2f3340fd793221ad6714.jpg1830431676_BR110284MSTS-V6.thumb.jpg.d80774351f7e9b28200da234b0b77601.jpg
1332684434_NSICRB727biMSTS-V5.thumb.jpg.12542a7c7986d10987398e9b96b40ac4.jpg1209733805_NSICRB812biMSTS-V5.thumb.jpg.75bc2c7fdec4496cdf12ddd0ce20d886.jpg1074317128_NSICRB853biMSTS-V5.thumb.jpg.f222f0129056ec3d1c835b9175f98679.jpg1062989665_NSICRBKD907MSTS-V5.thumb.jpg.47532c4bb3b84382d0eb9258585306ab.jpg379409601_NSICRBKD925MSTS-V5.thumb.jpg.cd8c121471f2967ef294a3dd9f5831b2.jpg1790780168_NSICRA621biMSTS-V5.thumb.jpg.6af27ecda2a94819a776adddf1b5f98f.jpg716020242_NSICRA651biMSTS-V5.thumb.jpg.e84e7a6a56d690a8a4e868d137950788.jpg815514814_NSICRA673biMSTS-V5.thumb.jpg.965564208c185aa2c78b0a0c21176973.jpg
Hello, @HWB
Thanks for your answer, but i can t find Shape Converter and Shape Viewer online.
Ican t start with a msts model download online? I have to install Train simulator.?
I spoke with this creator and i will be happy to have these creations into our game.
This is en exemple. Can you tell me if this models can be convert and if it s complicate or not and after that, i will do the conversion with him for the others models.
https://ajrailsim.pierreg.org/krs_scr/RRR_program1.jpg
You can see that he has creating a lot of beautiful things!
thanks
464436276_LaaersAMSTS-V5.thumb.jpg.0b4f3da0f9b55909f198d5b8ccc3da28.jpg1436102283_LaaersBMSTS-V5.thumb.jpg.b79c95315fecce99d8416257cbfae0b3.jpg12094991_FS_ZagsMSTS-V5.thumb.jpg.8c08c3f61c1fcaff375e4db671360d0c.jpg342384696_FS_ZgMSTS-V5.thumb.jpg.d3c98ddc63c4967d29ea289821774892.jpg195731787_CisternaErmewaMSTS-V5.thumb.jpg.0dd3d5e5bbe0303725feacc94fa52cc7.jpg1761104565_CisternaErmewabMSTS-V5.thumb.jpg.380728dd391d04b1e7fccde950fb04d3.jpg881679248_Cisterna_lotrasMSTS-V5.thumb.jpg.58b55a9bfb46ec2ed3ccf69e65888475.jpg1555283717_Cisterna_LungaMSTS-V5.thumb.jpg.2379c3f35088a30638985dc63470bddd.jpg71483669_Cisterna_transfesaMSTS-V5.thumb.jpg.d3d1115816c34de65a743e60218a48b3.jpg190241017_FS_VTG1MSTS-V5.thumb.jpg.cd0674a0a52f90b96f6eeb2fab76ff2f.jpg347448255_FS_VTG2MSTS-V5.thumb.jpg.c3769a30898b09e11ff01c6483e6755e.jpg1166239147_FS_VZMSTS-V5.thumb.jpg.477344b9973dee6713345eb9409f0827.jpg1319096033_FS_Vz1MSTS-V5.thumb.jpg.58c17b48b92607de3f48a4c48dd3c390.jpg2081255661_FS_VzEnaccoMSTS-V5.thumb.jpg.3f9f675e61bc6fe28cb5e82df5675d54.jpg1573513570_FS_VZkkMSTS-V5.thumb.jpg.3cdfa2cd350dcb32075493c2ffe80a50.jpg831275318_FS_VZkk_SentinaMSTS-V5.thumb.jpg.39ba68b5621309d6327a828c1a21fae1.jpg1432520332_FS_VzsMSTS-V5.thumb.jpg.c1d51f4b12984eb95cf5533fdb5bba45.jpg134263075_FS_Z_AgipMSTS-V5.thumb.jpg.71b1f7219f738833a64d4130480a8337.jpg
Hallo Hermann,
gibt es eigentlich schon Feedback von den Autoren der Modelle, ob diese die Absicht haben, die Modelle auch im MBS zur Verfügung zu stellen?
Hallo @Neo,
folgende Antworten liegen mir bisher vor
jean-pierre.gleonec:
Sie können meine Vorlagen mit Ihrer Software anpassen.
madmike:
Die Modelle sind frei für nicht-kommerzielle Nutzung. Umwandeln kann ich
nicht, ich mache nichts mehr in der Richtung.
Zimran Neno:
 Yes, that would be great if you would like to use these models for your 3D studio. Although I do not know how to adapt them exactly.
Lardman:
Gerne können Sie die Modelle benutzen für das Modellbahnstudio.
Gruß Hermann
vor 27 Minuten schrieb Neo:
Das wäre dann auch meine Frage, die Modelle sehen alle ziemlich cool aus....
Hallo Hermann,
danke für die Rückmeldung, die Autoren scheinen also nichts gegen eine Veröffentlichung zu haben. Planst du bereits ein Upload in den Online-Katalog?
Hallo @Neo,
da steckt noch Arbeit drin, es will immer noch nicht funktionieren mit den Animationen von Metasequoia nach MBS
Gruß Hermann
Hallo @Neo,
bei manchen Modellen gibt es die Email Adressen der Ersteller nicht mehr.
Es sind ja auch manche Modelle ab 2002, wie ich mit den Modellen verfahre weiß ich noch nicht
Hallo Herman,
was hältst du davon, die Modelle in einer Gemeinschaftsarbeit ins Studio zu bringen? Ich könnte mir vorstellen, dass andere Modellbauer so eine Konvertierung als gern gesehene Abwechslung sehen. Magst du einmal einen kurzen Überblick mit einer Beispieldatei geben, wie man diese ins glTF-Format konvertiert?
Hello @HWB you mean that only the MS train Simulator 2001 trains models can works here?
So we can t convert some recent models?
And i have a question,
It will be possible to you to give us to download a pack of models that you have autorisation and you have already convert?
thanks a lot for your works! and i don t lost hope to help you to convert some models :)
2021-10-26_195626.jpg.b3ccb80e888ebc6ba0a5340a1ca35a0c.jpg2029298233_TserVTb181602MSTS-V5.thumb.jpg.fc0ff4a28c3afb3da3dc0e71ba7216d3.jpg2077302229_TserVMc181602MSTS-V5.thumb.jpg.2a5c17daebc46fa06130507b398c967a.jpg799696206_TserVMe181602MSTS-V5.thumb.jpg.abc5e856603b4409ddcec2b96d0d72f9.jpg1758985482_TserVMd181602MSTS-V5.thumb.jpg.3ea5e5fc9bf9644903b8ca59cedb98e6.jpg513287547_TserVTa181602-motMSTS-V5.thumb.jpg.1c097cbad269675a1bd369a49bce0e39.jpg2021-10-26_195106.jpg.af3954f56f270b79189f9a1a5061e6b1.jpg
Bearbeitet von HWB
Hallo @Neo, und Interessierte,
1. Installieren Sie MSTS von 2001.
2. Shape Converter installieren.
3. Installieren Sie Shape Viewer.
4. Konvertieren Sie die Modelldatei in eine 3ds-Datei mit dem Shape Converter.
5. ace-Texturen mit Shape Viewer nach tga konvertieren.
6. Bearbeiten Sie das 3D-Modell und weisen Sie die Texturen zu, ich verwende Metaseqoia 4, speichern Sie als glb.
7. in MBS zum Test einfügen
8. Rechte einholen!!!!!! bei jedem MSTS Modell gibt es eine readme oder liesmich des Erstellers
9. glb Datei für Animationen in Sketchup oder Blender bearbeiten.
Gruß Hermann
Hallo Hermann,
was mich interessieren würde... haben die Modelle von sich aus wenig Polygone oder müßten für das MBS noch LOD Stufen erzeugt werden?
Hallo @EASY,
hier mal die Info vom Triebkopf
Gruß Hermann
Am 13/10/2021 um 22:22 schrieb HWB:
460350757_TD1MSTS-V5.thumb.jpg.a0f2b9cc9842afd4b783c031b116215c.jpg1149271637_TA1MSTS-V5.thumb.jpg.fe52259fe8843415ebf0042ae66f488a.jpg575855566_TB1MSTS-V5.thumb.jpg.d78facaadcc16c1a4de9dc156a47b041.jpg1554634904_TB1zMSTS-V6.thumb.jpg.ebbac3677e49be1caa6c279b9790a29e.jpg705334337_TC1MSTS-V5.thumb.jpg.0d1e062c823b14add60511c2b94313eb.jpgTalgo3.thumb.jpg.10f752bbdf20f29425661fa05d5dae5b.jpg
¡Yo lo quiero!
¿Se puede comprar?
Hola @David Teide,
puedes convertirlo por ti mismo, ya que los modelos de MSTS son gratuitos.
1. Instale el MSTS de 2001.
2. Instale el Shape Converter.
3.Instalar Shape Viewer.
4. Convertir el archivo del modelo en un archivo 3ds con Shape Converter.
5. Convertir las texturas ace a tga con Shape Viewer.
6. editar el modelo 3d y asignar las texturas, yo uso Metaseqoia 4, guardar como glb.
7. Insertar en el MBS para la prueba.
8. obtenga permisos!!!!!! con cada modelo de MSTS hay un readme o léame del creador.
9. editar el archivo glb para las animaciones en Sketchup o Blender.
Saludos Hermann
Traducción realizada con la versión gratuita del traductor www.DeepL.com/Translator
Bearbeitet von HWB
Hallo Modellbahnfreunde,
vorraussichtlich kommt die D2 der Bentheimer Eisenbahn durch den Graf Mec im Dezember auf eigener Achse auf die Strecke der Be zurück.
https://de-de.facebook.com/pg/GrafMec/posts/
1054219415_BeD2.thumb.jpg.46220cf174cc2c0265afbeecd32b74c8.jpg449977441_BeD2MSTS-V5.thumb.jpg.5b81af25c1d9df89ce556e77cb315a72.jpg
Kann vielleicht jemand das Fahrgestell des Modells animieren?
Gruß Hermann
Bearbeitet von HWB
@HWB hello! What do you think about create some pack with models with prmission who has already convert in the game, and we can download and play with i we vant.
Other question, I want to learn the conversion with the 9 step to convert! but i must have MSTS 2010? or i can install recent version?
We can convert all recent models from MSTS or only the 2010 version?
Thanks
vor 22 Stunden schrieb HWB:
Hallo @HWB
Kann der Prozess mit Open Rails anstelle von MSTS funktionieren?
Michel
