Herman
  1. Hello Pete, look at the track contact. When stopping the bentley hits this next track contact. But it is an acceleration contact to 25 km/h , so the Bentley immediately goes on. I placed the second TrCt a bit further. Correction not the case here because the deceleration of your Bently is high enough. The real cause is that you took the wrong name of the TC. See further. Kind regards, Herman
  2. Herman antwortete auf opaxs Thema in Anlagen
    Hallo @opax Sehr schöne Anlage. Ich fing an, mich umzuschauen und blieb beschäftigt, es gab so viel zu entdecken. Es hat mir sehr gut gefallen. Toll. Herman
  3. Herman antwortete auf brk.schatzs Thema in Modelle
    Vielen Dank! Herman
  4. Herman antwortete auf brk.schatzs Thema in Modelle
    Hello @brk.schatz I wondered why the direction of riding here is standard backwards, is that wanted ? Hallo @brk.schatz , ich habe mich gefragt, warum die Fahrtrichtung hier standardmäßig rückwärts ist, ist das gewollt ? Kind regards, Herman
  5. Herman antwortete auf Hermans Thema in Anlagen
    Hello, thanks for the likes. This layout started here. Hallo, danke für die Likes. Dieses Layout begann hier
  6. Herman hat Thema erstellt in Anlagen
    Hello, to all. I named the layout the same as Tec’s model Tecklingen Castle. Thank you @Tec . Another thank you to @Modellbahnspass, because this layout is inspired by one he made once. He gave me via the forum always inspiration building layouts. This automatic layout is made and tested to let two relative short trains drive simultaneously, not random, but alternating. Other trains wait in in two depots. There is an extra hidden panel. Here you can put your own train, choose if he stops at the station or not. He goes to the chosen depot blue or yellow. Use this only if the two other trains are visible. All the free camera’s exept “0 General view” show the view of a moving camera. Free cameras 8 and 9 are only available if their train is out of the depot. Discover it yourself, have fun, thanks for looking. Hallo, an alle. Ich habe die Anlage so benannt wie das Modell von Tec, Schloss Tecklingen. Vielen Dank an Tec. Ein weiteres Dankeschön an Modellbahnspass, denn diese Anlage ist inspiriert von einer, die er einmal gemacht hat. Er hat mich über das Forum immer wieder zum Bau von Anlagen inspiriert. Diese automatische Anlage ist so gebaut und getestet, dass zwei relativ kurze Züge gleichzeitig fahren können, nicht zufällig, sondern abwechselnd. Andere Züge warten in zwei Depots. Es gibt ein extra verstecktes Panel. Hier können Sie Ihren eigenen Zug platzieren und wählen, ob er im Bahnhof hält oder nicht. Er fährt in das gewählte Depot blau oder gelb. Benutze dies nur, wenn die beiden anderen Züge sichtbar sind. Alle freien Kameras mit Ausnahme von „0 General view“ zeigen die Ansicht einer fahrenden Kamera. Die freien Kameras 8 und 9 sind nur verfügbar, wenn ihr Zug aus dem Depot herausfährt. Entdecken Sie es selbst, viel Spaß, danke fürs Anschauen. 32A856F2-1E73-4C0C-84C1-2AE90E0D168C Regards, Herman
  7. Hello @Erwin In V9 können Sie auch zwischen Einfügen von Objekten oder Einfügen von EV oder beidem wählen. Kind regards, Herman
  8. Hello @Roter Brummer , I think the increase of train numbers was the most elegant solution. Thinking of what maybe is coming later, we can also rule it out by EV. But it is your EV and layout, and you want to keep the EV slim. So only for those that are interested. Hallo @Roter Brummer , ich denke die Erhöhung der Zugzahlen war die eleganteste Lösung. Wenn man bedenkt, was vielleicht später kommt, kann man es auch mit EV ausschließen. Aber es ist dein EV und dein Layout, und du willst den EV schlank halten. Also nur für die, die es interessiert. Dasselbe mit "Einfahrten gelb" Kind regards, Herman
  9. V5, Hello, it is best that the green depot has more trains (>=5 here) compared to the places in the SBHF (here 4). So that no incoming route can accidently been activated without a train coming out ( empty depot ). That route will then block the good working of this SBHF. Hallo, am besten ist es, wenn das grüne Depot mehr Züge (hier >=5) hat, als die Plätze im SBHF (hier 4). So kann keine eingehende Fahrstraße versehentlich aktiviert werden, ohne dass ein Zug herauskommt (leeres Depot). Diese Fahrstraße würde dann das gute Funktionieren dieses SBHF blockieren. Regards, Herman
  10. Hello @ern45 , in the settings. active when starting again. Regards, Herman
  11. Herman antwortete auf MarkoPs Thema in Modelle
    Hello, I am only with MBS since 2020, but I never saw it, exept as a parking sign. 025DEB17-74C2-414F-94AF-05D842441D0B, I think that is not what you are looking for. Hallo, ich bin erst seit 2020 bei MBS, aber ich habe es noch nie gesehen, außer als Parkschild. 025DEB17-74C2-414F-94AF-05D842441D0B, ich denke, das ist nicht das, was Sie suchen. Kind regards, Herman made by SualokinK
  12. Herman hat Thema erstellt in Anlagen
    Hello, to all. Presenting my first V9 layout. Thanks for watching and have fun. Hallo, an alle. Ich präsentiere mein erstes V9-Layout. Danke fürs Zuschauen und viel Spaß. Regards, Herman 13B06310-56A3-4999-8415-700AACB43DC5
  13. Herman antwortete auf Neos Thema in Beta-Bereich
    Hello, to all. This is just a little remark. When you use the integrated switch, the loop in the animation goes on, so the barrier guard keeps on turning. ( until you set the integrated switch off ). With the previous animation it goes from 0-1 and backwards 1-0. Is it possible (and easy to do) that the integrated switch works like for a door. Turn and stop, backwards turn and stop. ( of course we could still use the animation, or use a defer excecution and then stop the barrier guard with the EV) Hallo, an alle. Dies ist nur eine kleine Anmerkung. Wenn man den integrierten Schalter benutzt, geht die Wiederholung in der Animation weiter, so dass der Schrankenwärter sich weiter dreht. ( bis man den integrierten Schalter ausschaltet ). Mit der vorherigen Animation geht es von 0-1 und rückwärts 1-0. Ist es möglich (und einfach zu machen), dass der integrierte Schalter wie bei einer Tür funktioniert. Drehen und stoppen, rückwärts drehen und stoppen. (Natürlich könnten wir immer noch die Animation verwenden, oder eine aufgeschobene Ausführung verwenden und dann den Schrankenwärter mit dem EV anhalten) Übersetzt mit DeepL.com (kostenlose Version) C165A448-CD06-4065-A6DC-3A66C1FA66AE Kind regards, Herman
  14. Herman antwortete auf Roter Brummers Thema in Modelle
    Hallo @Roter Brummer Vielen Dank für Ihre Arbeit in diesem Fall. Mit freundlichen Grüßen , Herman
  15. Herman antwortete auf Roter Brummers Thema in Modelle
    Hello @Roter Brummer Hello, I saw your two DKW versions now released in the catalog (new). And your layout in this topic. From the front view they work flawless. When I turn the layout upside down, al the DKWs stay on their place, so the train machinist comes from the other side and he sees the "straight on" different compared to the DKW position. Or am I wrong? To illustrate what I ment , a comparision with DKWs from Seehund. Hallo, ich habe deine beiden DKW-Versionen gesehen, die jetzt im Katalog erschienen sind (neu). Und dein Layout in diesem Thema. Von vorne betrachtet funktionieren sie tadellos. Wenn ich die Anlage auf den Kopf stelle, bleiben alle DKWs auf ihrem Platz, so dass der Lokführer von der anderen Seite kommt und er die „geradeaus“ anders sieht als die DKW-Position. Oder liege ich da falsch? Zur Veranschaulichung ein Vergleich mit DKWs von Seehund. Übersetzt mit DeepL.com (kostenlose Version) Kind regards, Herman
  16. Herman hat Thema erstellt in Anlagen
    Hello, to all, First of all a big thank you to SualokinK for the models we can use here in this little demo. Some models have to be in the correct place relative to other models, Therefore they are together in a group. You may move the group, and the demo will work further. Do not dissolve the group to place the individual objects on other places. Thanks for looking. -------------------------------------------------------------------------------------------------------------------------------------- Zunächst einmal ein großes Dankeschön an SualokinK für die Modelle, die wir hier in dieser kleinen Demo verwenden können. Einige Modelle müssen an der richtigen Stelle im Verhältnis zu anderen Modellen stehen, deshalb sind sie in einer Gruppe zusammengefasst. Sie können die Gruppe verschieben, und die Demo wird weiter funktionieren. Lösen Sie die Gruppe nicht auf, um die einzelnen Objekte an anderen Stellen zu platzieren. Danke fürs Anschauen. Übersetzt mit DeepL.com (kostenlose Version) -------------------------------------------------------------------------------------------------------------------------------------- 967BC768-8348-4B61-A22B-5F4A44CCC5ED (draft maybe temporary unavailable, ) Kind regards, Herman
  17. 4DCBD1B9-8FA4-4F8F-AD2B-DAC2FF0FB409 Public bus !!! Bli Li, Bli Re, Warning, Stop F1E53081-7070-4CEE-ABC4-E42AC8AE38D1 Lamborghini Miura !!! warnblinker In the Lamborgini the blinkers are ok exept the warnblinker. Regards, Herman
  18. Thank you very much @BahnLand , that will certainly help Götz. Regards, Herman
  19. Hello @Goetz , a checkout in zip file. Integrated switch check.zip Excel format. Six cases found, in red. So only one more than you already know. (crossed message with Bahnland) Kind regards, Herman But only normal cars and buses checked here.
  20. Hello, 4DCBD1B9-8FA4-4F8F-AD2B-DAC2FF0FB409 Public bus 8A843BA6-74E1-41CF-A7DB-94DDDFD569B7 Icarus 66 Have the problem too. In the public bus it is harder to detect because in animation deprecated you can see that +- 80% of the animation has the orange blinker light off. Switch the integrated switch off and if you are unlucky the animation stops on an unwanted position, in stead of going quikly to a real off position, the blinker stays on. Probably @Chris06 said why. As a non model builder, I can not check that. Hallo, 4DCBD1B9-8FA4-4F8F-AD2B-DAC2FF0FB409 Linienbus 8A843BA6-74E1-41CF-A7DB-94DDDFD569B7 Ikarus 66 Habe das Problem auch. Im Linienbus ist es schwieriger zu erkennen, weil in der Animation veraltet kann man sehen, dass +- 80% der Animation hat die orange Blinker Licht aus. Schalten Sie den integrierten Schalter aus und wenn Sie Pech haben, bleibt die Animation an einer ungewünschten Position stehen, anstatt schnell in eine echte Aus-Position zu gehen, bleibt der Blinker an. Wahrscheinlich hat @Chris06 gesagt warum. Da ich kein Modellbauer bin, kann ich das nicht überprüfen. Regards, Herman
  21. Hello, sorry to come in. I tested those two and worked as should. Hallo, tut mir leid, dass ich mich einmische. Ich habe die beiden getestet und es hat funktioniert wie es sollte. Or do I not understand your problem ? Oder verstehe ich Ihr Problem nicht? Kind regards, Herman
  22. Herman antwortete auf HoWes Thema in Anlagen
    Hello @HoWe , tried again. ( V9 English version here ) Hallo @HoWe , habe es nochmal versucht. ( V9 Englische Version hier ) A1BF519C-F774-4CCA-9905-931DD59647E0 Kind regards, Herman
  23. Hello @raf.sonneville Just a method I use to detect the change of day/night. Take a light giving object and put it in automatic mode for day/night. ( you may hide this reference object ) If there is a change in day / night the integrated switch will toggle. This EV reacts on it. Das ist nur eine Methode, mit der ich den Wechsel von Tag und Nacht erkenne. Nehmen Sie ein lichtgebendes Objekt und stellen Sie es in den automatischen Modus für Tag/Nacht. ( Sie können dieses Referenzobjekt ausblenden ) Wenn es eine Änderung in Tag / Nacht der integrierte Schalter umschalten. Dieser EV reagiert darauf. The advantage is that if you use other times , the reaction stays correct. Der Vorteil ist, dass die Reaktion auch dann korrekt bleibt, wenn Sie andere Zeiten verwenden. Regards, Herman
  24. Katalog Hallo @UweDem , Ich sehe, Sie sind in V9. Was Sie suchen, finden Sie, wenn Sie den Mauszeiger über einen Menüpunkt bewegen. Beispiel für den Katalog Plugins Grüße, Herman. Wenn die vollständige Menüleiste oben nicht sichtbar ist. Siehe den Hinweis von Chris06 oder Phrontistes
  25. Hello @SY-DU , Eddy. Yes it can be seen. Here I see it always in your switches, but if I copy such switches to an empty layout, the problem is not there any more. ( and I tried with and without your custom texture cobblestone. A technical problem ? I inserted a picture, indeed, flickering. Certainly not my knowledge to help. Hallo @SY-DU , Eddy. Ja das kann man sehen. Hier sehe ich es immer bei deinen Weichen, aber wenn ich solche Weichen in ein leeres Anlage kopiere, ist das Problem nicht mehr da. ( und ich habe es mit und ohne deine benutzerdefinierte Textur Kopfsteinpflaster versucht. Ein technisches Problem? Ich habe ein Bild eingefügt, in der Tat, Flackern. Sicherlich nicht mein Wissen zu helfen. Kind regards, Herman
