Goetz
  1. Hallo Walter, wenn du das blaue Dreieck am Ende aktivierst und dann entweder den Gismo oder das graue Viereck benutzt, um ein Gleisende zu verziehen, dann werden dabei automatisch alle Spuren berücksichtigt. Viele Grüße Götz
  2. I haven't used it (and don't feel like trying it just now), but my assumption is that vehicles may have more than one attached view, e.g. forward and backward. If my assumption is correct, a value other than 0 won't make sense with a stationary camera ... Best Goetz
  3. Hello Herman, But of course. Every vehicle has a camera built in (cockpit view) and in the "Extras" section of the Online Catalog you may find a model "Kamera" These cameras can be selected for the "Activate camera" command. To my knowledge, the 10 hot keys for different views cannot be addressed from the EV Kind regards Goetz
  4. Hello Herman apparently, you've chosen one of the colours from the assortment for tracks. They have two sections. The left is used for sleepers and bedding, while the strip on the right is for the actual rail. It seems that the colour from the right hand side is used for the active part of the contact and the colour from the left is used for the inactive arrowhead. (This is just to clarify what you're actually seeing and why.) Kind regards Goetz
  5. kannst du mit dem MBS nicht. Jedenfalls nicht glaubwürdig. Du kannst sie bestenfalls an ein unsichtbares Fahrzeug koppeln, welches eine Schräge auf und runter fährt. Und das sieht dann wie Augsburger Puppenkiste aus. Denn das Bewegungsmuster für einen normalen Gang passt nicht zu den Stufen einer Treppe.
  6. Probably, because Lua creates variables (and table entries) when they don't exist and you assign a value to them. At Lua level, the command Switch["SwitchPoint"].state = Switch["Position"] maybe fine. And Lua won't know that the item in question has no state. The Lua table is merely a copy of the item's properties.
  7. Richtig schick, Brummi. Und gerade rechtzeitig für die Dinge, die demnächst mit V7 kommen werden.
  8. indeed, it is. I understand why you want to include the crossing. But your method seems strange and cumbersome. Why not have a simple "lock" boolean, which you turn on and off?
  9. Hello Herman, a simple crossing is not a switch. It therefor has no "state" property. Unlike double slip switches, which are of course a sort of switch. Kind regards Goetz
  10. Goetz antwortete auf prinzs Thema in Anlagen
    Hallo @prinz Ich habe selber gerade DaVinci Resolve bei mir installiert und finde die Software klasse. Lieben Gruß Götz
  11. Hallo Max, Da du beinahe immer irgendetwas ausgewählt hast, wäre diese Stelle permanent hervorgehoben. Und auf rotem Grund liest sich alles schlechter. Außerdem ist die Aufmerksamkeit des Anlagenbauers immer dort, wo er baut. Egal, wie laut du ihn aus der Ecke "anschreist". ... denke ich ;-) Götz
  12. Findest du in dem Beispiel alle Antworten? Oder wünscht du Erklärungen dazu?
  13. Bitte sehr: Haltkontakt vor Signal.mbp
  14. Genau. Oder schon im Vorfeld eine Version der Anlage speichern, die neben der EV nur das enthält, was man eventuell mit importieren möchte.
  15. Hallo Michl, leider gibt es keine Möglichkeit, die EV auszudrucken. Aber du kannst die EV einer Anlage (mitsamt der Anlage) in eine andere importieren. Dort landet sie dann in einem Unterordner "Ereignisse (importiert)" und du hast alles beisammen. Würde dir das helfen? Viele Grüße Götz
  16. Hallo Jürgen, in der grafischen EV geht es nicht, stimmt. Auf Lua Ebene ist es der key aus dem key, value Pärchen, welches man mit der "in pairs" Methode bekommt. Du bist an einem Punkt angelangt, an dem die grafische EV gegenüber Lua Skripten eher im Nachteil ist. Viele Grüße Götz
  17. Dann ist es doch einfach:
  18. Es geht schon, Günter. Aber ob es eine Vereinfachung ist ..? Beim Bahnübergang sollen die Schranken alle dasselbe tun. Das kannst du leicht mit einem Befehl erreichen. Aber wenn bei einer Kreuzung alle Ampeln zugleich den Befehl bekommen, auf Grün zu schalten, ist das nicht im Sinne des Erfinders. Wenn du also alle Ampeln mit einem einzigen Befehl umschalten willst und die Stellung dabei individuell verschieden ist, dann müsstest du die jeweilige Stellung in der Ampel selbst in einer Liste hinterlegen. Dann könntest du allen Ampeln mit dem Schlagwort "Strickmann-Kreuzung" sagen: schalte auf Stellung 1 in deiner Liste. Und dann ein paar Sekunden später: "Alle auf Stellung 2" Viele Grüße Götz
  19. Ja Günter, das geht Hier im Forum findest du eine Beispielanlage von Roter Brummer, welche dir zeigt wie es gemacht wird Viele Grüße Götz
  20. und wenn etwas nicht existiert, dann wird in Lua auf die Adresse nil verwiesen. Der String, den du daraus dann bilden willst, enthält deshalb keine Zeichen.
  21. schön geworden
  22. und der läuft prima. Details habe ich mir noch nicht angeschaut. Aber damit gespielt. Das Aus- und Einfädeln klappt sauber
  23. Ein "play von ... bis ..." würde mir auch gut gefallen. Andys Riesenrad ist ein klassiches Beispiel, bei dem man zunächst schrittweise die Animation abspielen will (bis alle Kabinen gefüllt sind.)
  24. Hallo Hermann, für eine vollständige Lösung habe ich gerade nicht die erforderliche Energie. Aber vielleicht hilft dir schon folgender Hinweis weiter? Die drei Signale, welche den Abzweig zur Nebenbahn decken (Blocksignal 1, Blocksignal 5 und Blocksignal 5e) sind technisch keine Blocksignale. Diese drei Punkte musst du wie eine Ausfahrt behandeln. Weil wie bei einer Bahnhofsausfahrt mehrere Wege zusammenkommen. Viele Grüße Götz
