973 -
Beiträge erstellt von Herman
20 hours ago, Klartexter said:
Nun ist das Modell dauerhaft in Deinem persönlichen Katalog gespeichert, selbst wenn der Entwurf gelöscht wird.
Hello @Klartexter , yes, but not usable even in a private layout, when the draft is expired. See Neo's answer.
Hallo @Klartexter, ja, aber auch in einem privaten Layout nicht verwendbar, wenn der Entwurf abgelaufen ist. Siehe die Antwort von Neo.
Kind regards, Herman -
16 hours ago, Goetz said:
Only the designer of the model can do that.
Hello @Goetz , a little correction. I just made a .mbe from a draft model and saved it locally. So it is possible, even as a non model builder.
And I can use that .mbe to get it back on my layout. But as soon as the draft is no longer on the internet, my .mbe or the counterpart in my 3D models are still there, but not usable on a layout anymore.18 hours ago, Neo said:The import option only stores references to the original asset and will be invalid once the original model gets deleted.
This answer made it very clear. ( only references )
@Goetz , so you are correct that only the model builder can make a .mbe out of a draft model, that stays usable.
@Goetz , @Neo thank you for the answers.
Regards, Herman -
Hello @Neo , first thank you for your answer. And of course I can see that most of the options RoniHB shows are clearly for model makers. That is normal.
Just to be sure I understand ( or do not ).18 hours ago, Neo said:It is not possible to save foreign models to a private storage.
So if I make an .mbe file ( export ) from a draft model of another user, and even if I put it directly in my 3D models as Klartexter said
, this model at my home will still be useless when the draft expires ?18 hours ago, Neo said:The author of a 3d model has to explicitly provide a mbe file in order to save a model for later use.
Yes they stay at use at home. ( see the indians in previous picture ). Or he can provide the specific files ( blender ) of the model, and I can put them in my 3D models too.
Hello, Hallo @Klartexter
Thank you, I must have done something wrong then because I know how to get things in My 3D models.
Danke, dann muss ich wohl etwas falsch gemacht haben, denn ich weiß, wie ich Dinge in meine 3D-Modelle bekomme.4 minutes ago, Klartexter said:Nur kann man es nicht auf Anlagen verwenden
Of course, that's normal and known. I put them in "Not to publish"
Das ist natürlich normal und bekannt. Ich habe sie unter "Nicht zu veröffentlichen" abgelegt.11 minutes ago, Klartexter said:Ich hoffe, Dir etwas weiter geholfen zu haben.
Fur sure, thank you ! Aber sicher, danke!
Greetings , Herman -
Hello, I apologize for the unintented and unwanted title, corrected.
Hallo, ich entschuldige mich für den unbeabsichtigten und unerwünschten Titel, korrigiert.
Greetings, Herman
Hello @RoniHB , your answer at @Thomas_103 , I come back here. It is a more general issue.
Hello members that can help here.
Hallo RoniHB, Ihre Antwort an Thomas_103, komme ich hier zurück. Es ist ein allgemeineres Problem.
Hallo Mitglieder, die hier helfen können.Yours : Ihr :
Here at my home , I do miss your options. Why ? Maybe because I'm not a model builder, but even then ?
Hier bei mir zu Hause vermisse ich Ihre Möglichkeiten. Warum eigentlich? Vielleicht, weil ich kein Modellbauer bin, aber selbst dann?On the other hand, I once saved a user's draft model by export, and saving it in my models. When the draft was expired it changed in a question mark. (but maybe I did something wrong).
So very happy to know how to hold draft models after the draft is no longer in the internet catalog.Andererseits habe ich einmal den Modellentwurf eines Benutzers durch Export und Speicherung in meinen Modellen gespeichert. Als der Entwurf abgelaufen war, änderte er sich in ein Fragezeichen. (aber vielleicht habe ich etwas falsch gemacht).Ich wäre also sehr froh, wenn ich wüsste, wie man Entwürfe behalten kann, nachdem der Entwurf nicht mehr im Internetkatalog ist.
Kind regards,
Herman -
Hallo Walter, @WalterW , @HWB led me to your topic.
I once had not yours, but a related problem and solved it with 2 single lanes. I made this to illustrate the basics of it. Also possible without Lua.
Maybe you can use the idea ? Kind regards, HermanHallo Walter, @WalterW, @HWB hat mich zu Deinem Thema geführt.
Ich hatte mal nicht dein, sondern ein verwandtes Problem und habe es mit 2 einzelnen Bahnen gelöst. Ich habe das hier gemacht, um das Prinzip zu verdeutlichen. Auch ohne Lua möglich. Vielleicht kannst Du die Idee verwenden? Mit freundlichen Grüßen, Herman -
Hello, just a little bit annoying. Manually placing containers on a floor plate. Since we now have containers with "snap points" they also snap automatic to the floor plate. (because floor plates snaps also to each other - maybe this cannot be solved). Now you have to set automatic snapping temporarely off to turn/move that container to the floor plate correct. Since a crane does the work correct you can of course use this to put each container on the wanted floor place.
Kind regards, HermanHallo, nur ein kleines bisschen ärgerlich. Manuelles Platzieren von Containern auf einer Bodenplatte. Da wir nun Container mit "Fangpunkten" haben, rasten diese auch automatisch an der Bodenplatte ein. (weil Bodenplatten auch aneinander einrasten - vielleicht kann man das nicht lösen). Nun muss man das automatische Einrasten vorübergehend ausschalten, um den Container korrekt auf die Bodenplatte zu drehen/verschieben. Da ein Kran die Arbeit richtig macht, kann man diesen natürlich auch benutzen, um jeden Container auf den gewünschten Bodenplatz zu stellen.
Hello Pete, take care that textures to come in the catalog do have length and width measurements as powers of 2.
Hello @Roter Brummer , I like your holding pins for containers. I've just discovered them in the catalogue. Thank you! Works nice.
Hallo @Roter Brummer, ich mag Ihre Haltestifte für Behälter. Ich habe sie gerade im Katalog entdeckt. Danke dafür! Funktioniert gut.Mit freundlichen Grüßen, Herman
Hello Ronny, @ronny_the boos_ schindler . Sorry I see at now you are only very recently on the forum. Therefore I tried to make a version of container load / unload that is very basic, yet - I hope - it does what you want. Try to understand what happens in the EV. And please if necessary, ask why here. Cranes are not the easiest to program if you are a starter with the studio. When I started with cranes I first played a while manually with them to understand their behaviour.
And it is alway : take a container, wait until the crane finishes, put that container , and so on every time the crane finishes put or take a specific container.
Only to help, I hope it's not "Böhmischedörfer" any more.
Container crane test.mbpHallo Ronny, @ronny_the boos_ schindler . Leider sehe ich gerade, dass Du erst seit kurzem im Forum bist. Deshalb habe ich versucht, eine Version von Container laden / entladen zu machen, die sehr einfach ist, aber - so hoffe ich - das tut, was du willst. Versuchen Sie zu verstehen, was in der EV passiert. Und bitte, wenn nötig, fragen Sie hier nach dem Warum. Kräne sind nicht so einfach zu programmieren, wenn man mit dem Studio anfängt. Als ich mit den Kränen anfing, habe ich zunächst eine Weile manuell mit ihnen gespielt, um ihr Verhalten zu verstehen.
Und es ist immer so: nimm einen Container, warte bis der Kran fertig ist, stell den Container ab, und so weiter, jedes Mal wenn der Kran fertig ist, stell oder nimm einen bestimmten Container.
Nur um zu helfen, ich hoffe, es ist nicht mehr "Böhmischedörfer".Mit freundlichen Grüßen, Herman
Hello Ronny, @ronny_the boos_ schindler , I think this is the same question as last week ( container loading/unloading) , where I tried to help a little. But not succesfull. ( English version and comments ). You did not react there why it was too difficult.
As @streit_ross said, I think we need more specific information of your problem and also of your EV skills.Hallo Ronny, @ronny_the boos_ schindler , ich glaube, dies ist die gleiche Frage wie letzte Woche ( Container Be-/Entladen ), wo ich versucht habe, ein wenig zu helfen. Aber nicht erfolgreich. ( Englische Version und Kommentare ). Sie haben dort nicht geantwortet, warum es zu schwierig war.
Wie @streit_ross schon sagte, denke ich, dass wir genauere Informationen über Ihr Problem und auch über Ihre EV-Kenntnisse benötigen.
Übersetzt mit DeepL.com (kostenlose Version)Mit freundlichen Grüßen, Herman
Hello @shpaul13 , as @RoniHB and @JimKnopf said. This happens with all rolling stock. And this kind of container can drive.
It happens only if you push them in each other manually at the end of a track ( virtual or not, does not matter ).
But test yourself, if you let the container drive by the system, all works fine.Hallo @shpaul13 , wie @RoniHB und @JimKnopf sagten. Das passiert bei allen Fahrzeugen. Und diese Art von Containern kann fahren.
Es passiert nur, wenn man sie am Ende eines Gleises manuell ineinander schiebt ( virtuell oder nicht, spielt keine Rolle ).
Aber testen Sie selbst, wenn Sie den Container durch das System fahren lassen, funktioniert alles einwandfrei. ( DeepL translate )Kind regards, Herman
Hello @ronny_the boos_ schindler , or look here, a little demo I once made.
Hallo @ronny_the boos_ schindler , oder schau mal hier, eine kleine Demo die ich mal gemacht habe. Aber englische Kommentare.Regards, Herman
5 hours ago, ronny_the boos_ schindler said:
1. Wie muss ich die EV schreiben das diese mir auch mehrere Waggons beläd.
Hello @ronny_the boos_ schindler , just a suggestion. When the train arrives at a first track contact, load or unload containers from wagon01 , when finished let the train advance until a new track contact where you load/unload the next wagon and so on.
Hallo @ronny_the boos_ schindler , nur eine Anregung. Wenn der Zug an einem ersten Gleiskontakt ankommt, be- oder entladen Sie die Container von Wagen01, wenn Sie fertig sind, lassen Sie den Zug bis zu einem neuen Gleiskontakt weiterfahren, wo Sie den nächsten Wagen be- oder entladen und so weiter.Nice regards, Herman
6 hours ago, ronny_the boos_ schindler said:
2. Wie muss die EV aussehen um Container abzuladen
Hello @ronny_the boos_ schindler , in the same manner as loading containers. Just name the container or floor place (object) where to put the container after the ->
Hallo @ronny_the boos_ schindler , auf die gleiche Weise wie das Laden von Containern. Benenne einfach den Container oder den Bodenplatz (Objekt), wo der Container nach dem -> stehen soll.
For the moment I leave the answer of question 1 to others. Die Beantwortung von Frage 1 überlasse ich im Moment anderen.Regards, Herman
Important / Wichtig
Of course only the basic. I use a counter in the crane to identify which container to take / put.
Natürlich nur das Wesentliche. Ich benutze einen Zähler in den Kran zu identifizieren, die Container zu nehmen / setzen. -
Hello @Eggu , I'm not sure about your question. Can you use this ? But it is a specific example where I read an animation value.
Hallo @Eggu , ich bin mir nicht sicher über Ihre Frage. Kannst du das verwenden? Aber es ist ein spezifisches Beispiel, wo ich einen Animationswert lesen.if $("Au 11445 Coaling plant").animations["Kran"].position > 0.955 then
return true
endRegards , Herman
Hello @SualokinK , maybe it has still to come, but is it possible to publish Juliane and Bettina walking, not only as a draft but for the catalog after Neo's approval ?
Hallo @SualokinK , vielleicht muss es noch kommen, aber ist es möglich Juliane und Bettina gehend zu veröffentlichen, nicht nur als Entwurf sondern für den Katalog nach Neo's Zustimmung ?Schöne Grüße, Herman
11 hours ago, Phrontistes said:
I have updated the layout "Select route by switches"
Hello, very nice done
Greetings, Herman -
First of all I want to thank Pete @220hotwheels for sharing information and discussions about the helicopter flight.
Please look also at his solution in "problems and solutions", especially his resque of the patient when the helicopter lands is very nice.
I made this mini layout, nothing special, it's basic. Probably some others are interested so I put it here as a draft.
How it works ? Just switch back to planning mode F9.Regards, Herman
CF876FCA-0D27-4A4A-A7C5-90FA7FEB9345 ( draft )
Zunächst einmal möchte ich Pete @220hotwheels für den Austausch von Informationen und Diskussionen über den Hubschrauberflug danken.
Schauen Sie sich bitte auch seine Lösung in "Probleme und Lösungen" an, besonders seine Darstellung des Patienten bei der Landung des Hubschraubers ist sehr schön.
Ich habe dieses Mini-Layout gemacht, nichts Besonderes, es ist einfach. Wahrscheinlich sind einige andere daran interessiert, also stelle ich es hier als Entwurf ein.
Wie es funktioniert? Schalten Sie einfach zurück in den Planungsmodus F9.Mit freundlichen Grüßen, Herman
Hi Pete. A remark.
Because you linked to the SX2; when the SX2 lowers because he follows the virtual track, then the Heli will lower too but he is far behind so you notice that.
Probably solutions.- Put the SX2 just beneath the Helicopter, not before.
or-
Did you never thought of this : the Helicopter is a vehicle. So let unlink him from the SX3 ( link to empty ) when he is on the horizontal track.
When the Helicopter is near enough to the virtual track, he will link automaticly to the track as a vehicle. Then you can give him the speed in stead of the SX2.
Maybe you have something with this ?
Greetings, HermanNote, I once made this one 72A8A11F-E6F2-4A94-9D90-59953246BF63, nothing special, just to give some other idea for an helicopter flight.
Note. For smoother flight, lower the values acceleration and deceleration of the SX2
Hi Pete, a happy 2024 to you. I'll have to look more in detail. By the way, the resque of the patient out of the Heli is really great
( Maybe a camera to follow that )
See you again,Regards, Herman
Also form me to all of you an happy new year 2024. My best wishes, certainly a good health.
Regards, Herman
Auch von mir an Sie alle ein frohes neues Jahr 2024. Meine besten Wünsche, sicherlich eine gute Gesundheit.
On 12/26/2023 at 5:00 PM, Roter Brummer said:
Man braucht also keine Zauberei und auch keine Jeanni, um demnächst die Container problemlos via Containerkran zu verladen.
Hello @Roter Brummer , still in working progress ? And not yet on the catalogue model ? "Sgns container carrier wagon" and "Lgs container carrier wagon".
Hallo @Roter Brummer , noch in Arbeit ? Und noch nicht am Katalogmodell ? "Sgns Containertragwagen" und "Lgs Containertragwagen".
Maybe I interpreted your text wrong. What I ment : manual placement via your contact points works great. When we use a crane directly to place on such models, the container is loaded to high, not on the model. ( exept if we use some floor an put the container on it - the so called old method).
Vielleicht habe ich Ihren Text falsch interpretiert. Was ich meinte: Die manuelle Platzierung über Ihre Kontaktpunkte funktioniert hervorragend. Wenn wir einen Kran direkt auf solche Modelle setzen, wird der Container zu hoch geladen, nicht auf das Modell. (Es sei denn, wir verwenden einen Boden und stellen den Container darauf - die so genannte alte Methode).
Complex tunnel system
in [International] Problems and solutions
Geschrieben · Bearbeitet von Herman
Hello members, maybe a question for a texture or a tunnel specialist ?
A tunnel tube single track from "Roter Brummer" , variation "Hochfront Loreley" is used.
The track combination has to stay. Another tunnel variation should be ok.
The tunnels are ok from the inside but because of the somewhat more complex track layout, there is a hole in the floor and the ceiling.
Solution for the floor --> a primitive flat layout with a texture from the catalog : ok for me.
This solution is also used for the ceiling , but as you can see I do not come near the "Loreley" texture. And a train sees the ugly distortion from his cockpit. All tips welcome.
Hallo Mitglieder, vielleicht eine Frage an eine Textur oder einen Tunnelspezialisten ?
Es wird eine Tunnelröhre eingleisig von "Roter Brummer" , Variante "Hochfront Loreley" verwendet.
Die Gleiskombination muss bleiben. Eine andere Tunnelvariante sollte in Ordnung sein.
Die Tunnel sind von innen in Ordnung, aber durch die etwas kompliziertere Gleisführung gibt es ein Loch im Boden und in der Decke.
Lösung für den Boden --> ein primitives flaches Layout mit einer Textur aus dem Katalog: für mich ok.
Diese Lösung wird auch für die Decke verwendet, aber wie man sehen kann, komme ich nicht an die "Loreley"-Textur heran. Und ein Zug sieht die hässliche Verzerrung aus seinem Cockpit. Alle Tipps sind willkommen.
