Track conversion
Sorry Herman, due to your misleading picture in the original post, I got the wrong idea what you're trying to accomplish. I thought you're trying to achieve this: my bad Goetz
Siggi 3D-Modelle
And so it is in the studio. But you only have access to the part of the catalogue that's relevant. No point in accessing models when you're on the starting page. What would you do with a model when no layout is open?
Siggi 3D-Modelle
Wenn der Entwurf eine Anlage ist, dann geh auf der Startseite zum Online Katalog und gib dort die Content ID der Anlage ein. Wenn es sich um ein Modell handelt, dann öffne eine beliebige Anlage, geh zum Online Katalog für Modelle und gib dort die Content ID des Modellentwurfs ein.
Siggi 3D-Modelle
On the starting page, you have access to layouts (and it wouldn't help here if you could select individual models) Once a layout is opened, you have access to models (and it's unlikely that you'll want access to a layout at this point) How can you not see the difference, Doug?
Track conversion
What's the separation between the two parallel tracks, Herman? That value is the offset in X for the position. That value is also what you want to add to the radius. All other values remain identical. Have a little think why that is. I'm sure it will help you with other, similar situations. Kind regards Goetz
Beginner question
Hello Kalle, Start a fresh layout open Online catalog -> Landscaping -> Modules you'll find a collection of cleverly designed layout sections made by Roter Brummer. Probably for what I just suggested, yes. Because Brummi remade many of his modules for V7 And it is highly recommended anyway. The advances in comparison to V5 are well worth the upgrade. Check out the V7 videos on the official train studio YouTube chanel for some of the highlights. Kind regards Goetz
Beginner question
Hello Kalle, can be found as extras. You may attach them to your switch points. They should snap in place. e.g. the guard rail has the content ID: 7DAE1618-32ED-4099-A666-43D76BB92CA5 and may be found under: Thoroughfares\Tracks\Model-oriented\Accessories Kind regards Goetz
Umsetzen im Bahnhof
Weil er die vorherige Richtung umkehren soll. Unter der Geschwindigkeit ist "relativ zur Fahrtrichtung" aktiviert. Wenn also die Geschwindigkeit zuvor schon negativ war, dann kehrt sich das Vorzeichen ins Positive um. Minus mal Minus gibt Plus Nicht der Gleiskontakt. Sondern die automatische Verzögerung in diesem Kontakt. So, als würdest du das Häkchen in diesem Feld entfernen:
Welcome to 2022
I'm glad you liked it And your "thank you" is more than enough.
Welcome to 2022
Hello George, When you create a user-defined event ... ... you'll typically want to call this event at another place. Here is where you pass your specific information on to the parameters that you established in the event's description Inside the user defined event, you can access the parameters via the "trigger" entry: And if you're wondering where the name "trigger" comes from, here's the answer. Sorry, I couldn't resist ... Kind regards Goetz
Dreischienengleis - Weiche H0 mit Abzweig H0e - Wie geht das?
Iwo, warum solltest du? Jeder hat freien Zugriff auf deinen Rechner und kann sich da dank Content-ID nach Lust und Laune bedienen. (Ich hoffe, du hörst den ironischen Unterton raus?)
Hallo Elluminatus, zuerst wählst du beide Gleisstücke gemeinsam (z.B. per Lasso oder per Strg + Linksklick) aus und formst daraus eine Gruppe Dann wählst du diese Gruppe aus und fügst sie unter dem Menü "Katalog" deinem persönlichen Sortiment hinzu. Du kannst in deinem persönlichen Sortiment Unterordner anlegen, um später beispielsweise Gleiskombinationen von Zugverbänden oder Landschaftselementen zu unterscheiden. Viele Grüße Götz
Lampen
Weil alle Objekte auf einer Anlage zusammenspielen müssen, Michael. Weil man möglichst viele Modelle auf einer Anlage unterbringen möchte, ohne dass der Rechner in die Knie geht. LOD Reduktion in größerer Entfernung sorgt dafür, dass der Rechner nur so viel berechnen muss, wie überhaupt noch erkennbar ist. Bedenke, dass dein Blickfeld zur Ferne hin immer breiter wird. Dass du in der Ferne mehr Objekte nebeneinander siehst als in der Nähe. Da macht es sehr viel aus, wenn jedes dieser Objekte nur noch aus ein paar einfachen Flächen mit geringer aufgelösten Texturen besteht. Sämtliche Spiele sind nach diesem Muster gebaut. Weil es professionell ist. Ich hoffe, dass du ein besseres Verständnis für die Materie entwickelst. Dass du lernst das Gesamtbild zu betrachten, in welches sich dein Modell einfügen muss. Viele Grüße Götz
Welcome to 2022
I'm sorry, George - didn't realise that you cannot know this The number is the content ID of the demo layout which I uploaded for you. On the start page of the 3D train studio, select the online catalog. Then transfer the Content ID into the search field at the top right: Kind regards Goetz
Lampen
Ist die Ankunfthalle im Original 1,8 Kilometer lang? Nein? Dann kennst du die Antwort, Michael
Umsetzen im Bahnhof
Umsetzen im Bahnhof
Hallo Verstummel, wenn der Triebwagen stoppt und die Bedingung "steht auf dem Bhf 3 Stumpfgleis" erfüllt ist, dann wird nur die Weiche bhf_3_w2_re umgeschaltet. Alle weiteren Befehle stehen unterhalb der grauen Trennlinie. Was dort steht wird immer dann ausgeführt, wenn die Bedingung nicht erfüllt ist. Auf dem Stumpfgleis bekommt der Triebwagen deshalb keine Geschwindigkeit zugewiesen. Dieser Fehler wird weitere Folgefehler nach sich ziehen. Rechne also damit, dass du noch mehr Änderungen vornehmen musst. Viele Grüße Götz
Maxweis Modellbau-Werkstatt
Laienhaft gesprochen ist das eine Kupplung, die vom Führerstand aus bedient werden kann. So kann der Lokführer selbständig Waggons an und abkuppeln und ist nicht auf die Hilfe eines Rangierers angewiesen, der die Schraubenkupplung für ihn ein- und aushängt. Wikipedia: Rangierkupplung
EV im Bahnhof Trossingen
Hallo Jube, das Video gibt es: Viele Grüße Götz
Welcome to 2022
I'm sorry, George. I didn't pay enough attention. There's no direct means by which you can read out the remaining time of a timer. Simon already said so. And offered a solution too. Personally, I would use two timers to achieve what you asked for. One for the actual event. A second one (with a period of 1 second) for the countdown until the first timer has expired. Here's an example: 7563B6DE-7D2C-43CC-BACF-01407F057322 Kind regards Goetz
Welcome to 2022
Yes George, you can. And it's really easy too: Insert the action "deferr execution" from the time control category at the appropriate place Yes, you can do that too. Kind regards Goetz
schlagwort an mehrere signale
Das war hier, in diesem Video: Viele Grüße Götz
hallo
nein, das geht leider nicht
hallo
Hallo Matthias, du findest sie unter Online-Katalog Bahnfahrzeuge Elektroloks Altbau-Lokomotiven Viele Grüße Götz
Add a graphic
Yes, George, that's doable. The easiest may be that you select the object "Ebene" from the category "Online catalogie -> primitives" to your layout. Now select the brush icon in the properties window of this object. Select the folder icon at the end of the "texture" entry field. Select "File" Select your .jpg image from your picture foilder Finally, adjust length and width of the "Ebene" object to match the aspect ratio of your image. Kind regards Goetz
